Post Your Dyno #'s And Mods!
neeman77
yup needs about 30 percent more fuel. it burns cooler and is higher octane than 93 (about 110). i get e85s for $2.39 anf 93s are going for $3.40 so even if i have to run 30 percent more fuel im only spending $3.10.
AirborneS2K
im glad you are happy with your car. what was your duty cycle and a/f ratio with 750 cc injectors. when i was running 1000cc injectors, i was at 95 percent duty cycle at 21 psi. dyno numbers can vary but injector duty cycle doesnt.
AirborneS2K
Originally Posted by Peter@ISP,Nov 19 2007, 04:35 PM
AirborneS2K
Here is all of my mods and as far as numbers cant say for sure need a dyna pack dyno to find out just keep spinning on a dynojet or any other roller based dyno. as soon as i can get to a dyno pack i will give numbers and vids for all to see. BTW Fperra and i have a very similar setup but i am sure that he is most likely whooping my ass as far as numbers go.
Modifications:
Engine/Cylinder Head
Allianz Technologies Ported Head
1.5mm Oversized Stainless Intake Valves
Nitrite Coated Exhaust Valves
Custom Dual Valve Spring Setup w/ Titanium Retainers (will handle 11,000+ RPM)
Engine/Cylinder Block
Ross Pistons 0.020" Oversized Pistons, Banodized Coating
Pauter Rods
Polished and Balanced Crank
Iron Sleeves Installed By Benson
Hand Build With Meticulous Attention To Detail
Turbo/Intake System
4.50" x 18.0" x 12.1" Garrett Intercooler (3" Outlet, 2.5" Inlet)
Custom Stainless Steel Intake Piping
Tial 44mm Waste gate
Tial Blow Off Valve
GARRET GT35R (Dual BB)
Full-Race Exhaust Manifold
T-Band Clamps Used On All Silicone Couplers
Custom 4" Exhaust system
Full-Race Custom Sheet Metal Intake Manifold w/ Velocity Stacks
Erick's Racing 72mm Throttle Body
Steel Braided Oil Feed and Return Lines
Exhaust manifold and piping allows for interchanging turbos to modify the power band
Fuel System
Aeromotive A1000 In-Line Fuel Pump
Aeromotive Fuel Pressure Regulator
-10 AN Steel Braided Feed And Return Lines
10 Gallon Trunk Mounted Fuel Cell (w/ Sponges)
Barry Grant Fuel Filters w/ Replaceable Elements x 2 (before and after pump)
MSD 1080cc Injectors
Ignition System
AEM C2DI Ignition System
Accel Coils
Magnacore Spark Plug Wires
NGK Iridium Spark Plugs
Wheel/Suspension
Volk CE28n Bronze Wheels, 17" Diameter, 9"/rear, 7.5"/front
Falken RT 615 255/40/17 rear tires
Falken RT 615 225/45/17 front tires
Buddy club Racing Spec 2 full coil over Suspension
Corner Balanced, Aligned
Spoon X-Brace
Drive train
2004 Cryo-Treated Transmission
Kaaz Rear Differential
Comptech Differential Bearing Cap
Fidanza Flywheel
Competition Clutch Ironman Clutch (4 Puck disk)
Electronics/Tuning
AEM EMS w/ Harness Extension (Mounted Under Driver's Seat)
AEM 3.5 BAR MAP Sensor
Greddy 60mm Oil Pressure Gauge
Greddy 60mm Oil Temp Gauge
Greddy 60mm Water Temp Gauge
Greddy 60mm Boost Gauge
Greddy 60mm EGT Gauge
Greddy Profec-B Boost Controller
Motec Wideband O2 Sensor w/ Dash Display
Optima Red Top Battery
Battery Relocated To Trunk
Modifications:
Pauter Rods
Turbo/Intake System
Tial Blow Off Valve
Fuel System
Ignition System
Accel Coils
Wheel/Suspension
Spoon X-Brace
Drive train
Fidanza Flywheel
Electronics/Tuning
Originally Posted by dans2k,Nov 19 2007, 11:31 PM
360 WHP/233TQ
Comptech SC with AC.
9# pulley.
AEM EMS 1052.
650 RC injectors
9# pulley.
AEM EMS 1052.
650 RC injectors
heaser primarys are ram horn style 2" with 3" downpipe and at at full boost with c16 its in excess of 800 hp. Everyday driving it stays around 1.5 bar with 550 to the tires with 93 pump and believe it or not i still have back pressure dont ask me how but i do. Havent had any problems with the way it runs or even afr's. My biggest issue is trying to keep it tuned as the seasons change in the mtns of of NC. All 4 seasons are distinct and have to have a retune per season. gets kinda of expensive for house calls but at least it stays running great.
