Post your FI gauge setups
Old Sep 21, 2020 | 01:52 PM
ECaz34's Avatar
sorry to thread jack a little, is it difficult to wire up gauges? Ive thought about adding some to mine just haven't found and good DIY on how to do it.
Old Sep 21, 2020 | 02:08 PM
Madkows's Avatar
https://www.s2ki.com/forums/s2000-un...lenoid-951029/
Unless your gauges are connecting to an aftermarket ECU, then you'll need to know what you're pinning out to for what wire, but if they're "dumb", then that main picture is pretty much all you'll need, just figure out what wire does what on the gauge and match it with the blade terminals. Was pretty easy to do.
Old Sep 24, 2020 | 07:55 AM
johnckeen's Avatar
Originally Posted by F1TwoThousand
Gear/RPM/TACH WITH WARNING LIGHTS
PSI
A/F
THROTTLE %
INTAKE TEMP
COOLANT TEMP
LAMBDA CONTROL FEEDBACK
BATTERY VOLTAGE
FUEL PRESSURE
SPARK TIMING
(ELEVATION AND GPS SPEED ON BOTTOM NOT WORKING AS CAR WAS UNDER SHED)https://youtu.be/cH_KUJRdpGs
What AEM dash is that?
Old Sep 24, 2020 | 09:46 AM
afzan's Avatar
PSI
A/F
THROTTLE %
INTAKE TEMP
COOLANT TEMP
BATTERY VOLTAGE
FUEL PRESSURE
SPARK TIMING
nice clean install. That’s exactly where I was planning to mount my CD5! How did you mount it and how did you run the wiring?
Old Sep 24, 2020 | 09:49 AM
Mijae007's Avatar
Defi bf boost gauge, hks turbo timer showing voltage and my phone on hondata app via bluetooth
Old Sep 24, 2020 | 10:07 AM
ECaz34's Avatar
is that a magnetic mount for your phone?
Old Sep 24, 2020 | 10:16 PM
F1TwoThousand's Avatar
I used the modifry dash bracket 3m molding tape and drilled a hole through thr bracket and screwed in a fastener for the CD5. Nice clean easy to remove install. I think this is the best set up period. And of course the warning screens and options are the best hands down.
S2000_FUN
Mar 17, 2018 05:09 AM
95PreludeSi
Cars for Sale
Mar 21, 2016 12:41 PM
paulsayavong
Mar 10, 2016 03:26 PM
