Precision 6262/6265
Old Mar 10, 2009 | 09:10 AM
ScorpionT's Avatar
Default Precision 6262/6265
Does anyone here run this on an S2k? Ive had great results with them on other cars, but never had one on an S.
Old Mar 10, 2009 | 09:12 AM
Soul Coughing's Avatar
im pretty sure Rob! is running that turbo. Not 100% though
Old Mar 10, 2009 | 12:17 PM
Peter@ISP's Avatar
Former Sponsor
i just installed this turbo on my car. so far so good. having boost tapering issues though. im going to upgrade my intercooler and up my timing to see if it helps
Old Mar 10, 2009 | 12:45 PM
RangOs2000's Avatar
wow that probably pulls sooooo hard
Old Mar 10, 2009 | 02:09 PM
rob!'s Avatar
I run the 6165 which is very close in relation to the 6265. I picked up about 30hp on the same boost level on my inline pro log manifold on my last retune just by switching to this turbo from the sc6152. car made 525whp at 19psi and felt super strong.
I really would like to know more info on these turbos since precision didnt really release anything about them. I basically just know it has a 65mm turbine wheel. If anyone has more info on them it would be nice.
Old Mar 10, 2009 | 02:18 PM
dsddcd's Avatar
I called them to get information and they told me "We found that compressor maps are unnecessary and that no one uses them so we don't make them."
WTF
Old Mar 10, 2009 | 03:19 PM
ScorpionT's Avatar
Nice dyno Peter!
Rob, the turbo you have uses a compressor similar to a GT35R matched with a turbine the size of a P trim but with better aerodynamics. The 6262 uses an even better compressor machined from billet aluminum. They flow more air and can sustain higher boost pressures.
dsddcd, compressor maps are very expensive to have made, and most people dont use them. They are nice to have as a tool to pick the proper turbo, but most guys dont need them or use them. If you want info on a turbo ask someone who does a lot of tuning.
Old Mar 10, 2009 | 05:37 PM
rob!'s Avatar
so the 6165 will produce more power then a 35r? thanks for the info on this.
Here is a dyno from Jeff Evans website from my 6165 dotted line is the 6152. Both are at 19psi.
Old Mar 10, 2009 | 06:58 PM
ScorpionT's Avatar
They would be close but the 6165 is slightly better than a 35R. The 6152 uses the same compressor but essentially uses a T31 stage 5 turbine wheel.
Old Mar 10, 2009 | 07:01 PM
dsddcd's Avatar
There is engineering and there is opinions, in the automotive industry there are too many people that live by hearsay and not fact.
