Precision turbo blown..
Old Oct 18, 2012 | 03:19 PM
  #41
herecomesboost's Avatar
Pics from Derric:
Old Oct 18, 2012 | 03:55 PM
  #42
passmans2kny's Avatar
china..
Old Oct 18, 2012 | 06:37 PM
  #43
all4spl's Avatar
Thanks kyle. Ya I'm not sure what happened here.
Old Oct 19, 2012 | 06:25 AM
  #44
InductionPerformance's Avatar
Originally Posted by all4spl
Okay so I have a precision 6262 and i have a 10an return and a 3an feed with a restrictor and yesterday found out that the turbo is gone. Has bad shaft play and looks like it scuffed the housing a bit. The turbo is only 4 months old and I emailed precision. Not sure what they will do but does anyone have an idea what could have happened? The feed is coming from the vtec solenoid and the return is going to the front engine cover.
I don't care what anyone has to say. These are your issues. I've probably sold, installed and tuned more PTE, Garrett, BEP, BW units than 80% of the people on this forum. I've ten cars in the shop right now with PTE units. One of those being an S2000. You absolutely don't get oil from the VTEC solenoid. Especially with a restrictor. It's the internet but I am not trying to be an ***hole. Live and learn on this one.
Old Oct 19, 2012 | 07:34 AM
  #45
JUSTINTHECOASTIE's Avatar
Old Oct 19, 2012 | 08:47 AM
  #46
all4spl's Avatar
plan is to ditch the stock oil pressure sensor and feed off that. and should i use or not use a restrictor? Guess I could go without one and keep an eye out for oil. Would it be on the intake or exhaust side most likely?
Old Oct 19, 2012 | 09:55 AM
  #47
siadam's Avatar
Best thing I've found that I like is the sandwhich adapters. Filtered oil, and it makes it nice to run other lines like oil pressure/etc without having to have crappy brass fittings all over your engine bay.
Old Oct 19, 2012 | 11:10 AM
  #48
vduber's Avatar
I agree with siadam sandwich plate keeps it much cleaner but if you go off the sensor port you will need a tee with a 1/8bspt male end to thread or since I already had a 1/8npt tee I just got a 1/8 bspt and a 1/8npt on the other side of the fitting and it was done with. Yes you still need a restrictor with a jb turbo
Old Oct 19, 2012 | 02:14 PM
  #49
Reapur's Avatar
Don't ditch the oem oil pressure sensor unless you have a dedicated pressure gauge installed and setup right.
Just T off with a fitting and re use the the oem sensor on the end of the fitting.
Old Oct 24, 2012 | 02:36 PM
  #50
all4spl's Avatar
just an update. they said it was starved of oil. they are fixing it under warranty and i told him im going to change oil feed to the oil pressure and get rid of the restrictor. if it starts smoking or any other issues, i will call him back and go from there.
