PRECISION TURBO - Flange? Oil return line fitting?
Old May 7, 2013 | 08:50 PM
ktpp35's Avatar
Default PRECISION TURBO - Flange? Oil return line fitting?
Hello everyone,
I bought a precision turbo and don't have the downpipe or the elbow. I do want to get one made and I'd really want some suggestions into what I should be buying as wanting to keep the stock cat and running a cutoff switch such as this one:
http://www.modernperformance.com/pro...aliber_exhaust
If I want to run the stock exhaust, will it restrict my motor hence harming or shortening the life of the engine?
I'm open to other suggestions or routes but I'd really be curious as to any recommendations.
Also, how do I figure out the sizing for the fitting that is tapped into the oil pan from the oil return line on the turbo?
I'd most likely need a new fitting as the previous owner did not include a tapped oil pan.
Peter
Old May 8, 2013 | 03:50 AM
wy2slow_z's Avatar
Best suggestion ever: tap timing chain cover for your oil return. -8 or -10 an bing will be fine.
Old May 8, 2013 | 04:38 AM
baZurk's Avatar
When running a stock exhuast, heat is the thing you need to worry about.
Old May 8, 2013 | 05:31 AM
herecomesboost's Avatar
-10 AN return (to the timing chain cover)
Old May 8, 2013 | 08:18 AM
ktpp35's Avatar
Thanks guys, any idea which vendor to go to get the bing to weld onto the timing chain cover?
Old May 8, 2013 | 08:52 AM
gofast04's Avatar
if you go into the fi for sale theres a guy (catsS2000) hes who i bought mine from he sells them just pm him very fast shipping and very helpful!
Old May 8, 2013 | 08:11 PM
ktpp35's Avatar
thanks i actually contacted him about it! anyone know the deal with the flange size for precision turbos?
Old May 8, 2013 | 09:20 PM
5thgen's Avatar
I believe it is based off a garrett t3 for the return line. At least the gasket I used was for a garrett t3.
The flange/tube I just made myself. I don't like using a hose fitting so close to the turbo, as it always crowds an already tight space.
And the only technical drawing picture I could find from precision that at least had dimensions.
Funtimefrankie
Nov 24, 2013 10:47 AM
seoul2k
Apr 26, 2011 04:40 PM
Mijae007
Apr 19, 2011 06:43 PM
phils2k
Nov 5, 2008 11:40 AM
joeyriveira
Nov 12, 2003 08:20 PM
