Primary gear reduction? Huh?
I´m looking for different gearbox options right now and want something close to stock.
Have one problem right now and that´s "Primary Gear Reduction", what´s that? Maybe hard for me to translate or something but can´t find what that stands for.
Only see this on the stock gearbox, not on the other brands.
Is that a gear on the imput shaft before the other gears? Do you add this to the gear ratios?
Example:
AP1
6-speed, close-ratio
Primary Gear Reduction - 1.160
1st gear - 3.133 --- Est speed @ 9000rpm ~ 45mph
2nd gear - 2.045 --- Est speed @ 9000rpm ~ 60mph
3rd gear - 1.481 --- Est speed @ 9000rpm ~ 90mph
4th gear - 1.161 --- Est speed @ 9000rpm ~ 115mph
5th gear - 0.970 --- Est speed @ 9000rpm ~ 135mph
6th gear - 0.810 --- Est speed @ 9000rpm ~ 160mph
Reverse - 2.800
Thanks!
Example:
AP1
Reverse - 2.800
Thanks!
Corey: I know but can´t afford it right now, want a low milage tranny and it´s crazy expensive over here.
I forget the breakdown, but I know the ap2 trans with the primary gear reduction simulates an equivalent 4.22 rear end ratio in the (first 4 gears only) compared to say the non primary gear reduced ap1 trans. If that helps at all.
Originally Posted by wadzii' timestamp='1322013163' post='21179496
its the "last" gear in the transmission.
Changing this has the same effect as changing the final drive. most transmissions dont have this.
