Primary gear reduction? Huh?
Old Nov 22, 2011 | 08:46 AM
B5254T4's Avatar
Default Primary gear reduction? Huh?
I´m looking for different gearbox options right now and want something close to stock.
Have one problem right now and that´s "Primary Gear Reduction", what´s that? Maybe hard for me to translate or something but can´t find what that stands for.
Only see this on the stock gearbox, not on the other brands.
Is that a gear on the imput shaft before the other gears? Do you add this to the gear ratios?
Example:
AP1
6-speed, close-ratio
Primary Gear Reduction - 1.160
1st gear - 3.133 --- Est speed @ 9000rpm ~ 45mph
2nd gear - 2.045 --- Est speed @ 9000rpm ~ 60mph
3rd gear - 1.481 --- Est speed @ 9000rpm ~ 90mph
4th gear - 1.161 --- Est speed @ 9000rpm ~ 115mph
5th gear - 0.970 --- Est speed @ 9000rpm ~ 135mph
6th gear - 0.810 --- Est speed @ 9000rpm ~ 160mph
Reverse - 2.800
Thanks!
Old Nov 22, 2011 | 02:31 PM
steven975's Avatar
not sure if it's before or after the main gears, but it is cumulative.
So, for example, in 4th it is 1.16*1.16*4.10 = 5.50
Old Nov 22, 2011 | 04:52 PM
wadzii's Avatar
Banned
its the "last" gear in the transmission.
Changing this has the same effect as changing the final drive. most transmissions dont have this.
Old Nov 22, 2011 | 05:25 PM
Corey Maurer's Avatar
Just get yourself the full blown supra tranny
Old Nov 22, 2011 | 08:33 PM
B5254T4's Avatar
That´s what I thought, hmmm... How do you calculate this? Add that number to each gear ratio?
Corey: I know but can´t afford it right now, want a low milage tranny and it´s crazy expensive over here.
Old Nov 22, 2011 | 10:06 PM
s2000Junky's Avatar
I forget the breakdown, but I know the ap2 trans with the primary gear reduction simulates an equivalent 4.22 rear end ratio in the (first 4 gears only) compared to say the non primary gear reduced ap1 trans. If that helps at all.
Old Nov 23, 2011 | 12:02 AM
twomodified4u's Avatar
just multiply the final drive by 1.16 and this should be equivalent. so a stock would be close to 4.75
Old Nov 23, 2011 | 01:26 PM
S2SEXY's Avatar
http://www.turnzero.com/technical_re...ear_calculator
Old Nov 23, 2011 | 01:49 PM
B5254T4's Avatar
Thanks guys, great info! And that calculator will help, I did it the old fashion way, pen and paper.
Old Nov 23, 2011 | 05:39 PM
camuman's Avatar
Buy it for me and we all good.
