Problem with Greddy turbo kit question
Old Aug 19, 2007 | 03:50 PM
Wandaniers's Avatar
Default Problem with Greddy turbo kit question
Ive had the kit on for about a week and I just started to get on the pedal a bit because I had to break in the clutch. But the car is hesitating when I stomp on it and it just like bogs and backfires when the pedal is to the floor in first gear, but when I ease on it - it goes well and spools fine. Also I was wondering if it could be from running to rich or do I just it to be tuned? Because last night in 4th gear I took it to 8k and when I shifted I shoot out a fire ball and kind of backfired as well. I am not to sure what is wrong, please let me know if anyone has any idea's. Thanks
Old Aug 19, 2007 | 03:51 PM
Mystiqueskillz's Avatar
I think you should get your car tuned first before driving it hard.
Old Aug 19, 2007 | 04:20 PM
hokies2000's Avatar
Just to clarify, fireball out of the exhaust is generally afterfire: unburnt fuel in the exhaust stream that gets ignited on the way out. I'm guessing you're catless? If so, this can happen. But it does sound like you may be running rich, amongst a host of other potential issues (timing, etc). Like mystique said: get tuned before driving it any harder. Tuning is less than a new motor.
Old Aug 19, 2007 | 04:24 PM
ChefJ's Avatar
Go see a tuner.
Just because the emanage comes pre-programmed doesn't meant it is going to be perfect for every car.
Old Aug 19, 2007 | 04:45 PM
Reagent's Avatar
Originally Posted by ChefJ,Aug 19 2007, 04:24 PM
Go see a tuner.
Amen brother! But the Ultimate that comes with the kit is locked isn't it?
Old Aug 19, 2007 | 05:04 PM
passmans2kny's Avatar
why are u even driving the car hard when its untuned? or even at all
Old Aug 19, 2007 | 05:09 PM
Wandaniers's Avatar
Yes that is what I will do, schedule for tuning because I definatly dont want to mess anything up. I have way to much time an money into it to blow it. Also I am catless with a j's 70rr, exedy hyper single, and 4.56 gears and I am using the supplied emanage ultimate.
Old Aug 19, 2007 | 05:11 PM
Wandaniers's Avatar
Well the Ultimate comes with a base map, and I needed to break in the clutch before tuning.
Old Aug 19, 2007 | 05:23 PM
hokies2000's Avatar
Breaking the clutch in usually means driving it fairly timidly; not at 8k rpm's or stomping on it
Old Aug 19, 2007 | 05:32 PM
Wandaniers's Avatar
I have only got on it a couple times just to figure out if I had any problems after I got 400 miles on the clutch, and I only took it to 8k once last night. I have been staying under 6k.
