Problem with Greddy turbo kit question
Old Aug 19, 2007 | 08:59 PM
passmans2kny's Avatar
be careful, don't want your engine going boom
Old Aug 20, 2007 | 04:23 AM
Ray K.'s Avatar
I can't imagine it's the tuning if it's what comes the kit. I would assume Greddy tunes the Emanage pretty conservatively so it can be as generic as it needs to be. I would look at hardware before software in this case or else you'll use a retune as a band aid to cover up a hardware issue. At least start by going to Autozone and having the codes read to see if there is anything to lead you in the right direction.
Old Aug 20, 2007 | 10:18 PM
Phillie's Avatar
I would say its running rich. I had the same problem you had. Stab the throttle and it would bog but ease into it you're fine. My wideband would just peg at 9.99 either way it went. Better to run rich then lean.
Old Aug 20, 2007 | 10:39 PM
S2Fire's Avatar
Banned
but what u can do before u go to dyno tune...u can check out the spark plug and let see how it look like....
Old Aug 20, 2007 | 10:47 PM
nearwater4me's Avatar
I have a totally noob question, guys.
Can anyone elaborate on why it's safe to run rich, but risky to run lean?
Why is it safer/risky, and what's the worst case scenario?
Thanks
Dan
Old Aug 20, 2007 | 11:21 PM
EOE's Avatar
EOE
Keeps the temps down..?
Old Aug 21, 2007 | 05:22 AM
Ray K.'s Avatar
I agree not much, but still I would be suspicious of something other than software initially. Check for leaks. Perhaps the BOV he leaking under boost and he isn't getting all the air into his motor or something wacky like that. I'm just guessing. I'm really not sure what would make a quick stab of the throttle different than easing into boost.
Old Aug 21, 2007 | 06:48 AM
brainwo's Avatar
Thanks
Dan
Lean burn will cause pre-ignition/detonation.
Link to Pre-ignition/denonation
Old Aug 21, 2007 | 08:05 AM
Chris_Lum's Avatar
Why do people think that the basemap, which was tuned with a stock cat, will run just peachy on a catless car?
There's most likely nothing wrong with your hardware or software, go get a tune or put your cat back in if you want it to run better. And yes, a step colder than stock for spark plugs would be a good thing.
Old Aug 21, 2007 | 10:09 AM
Wandaniers's Avatar
I have colder spark plugs, also with my j's 70rr it is a one piece exhaust with no cat. I will be getting it tune and and installing my wideband, so hopefully that with fix my problems.
