Profec e01 and EMS
Old May 4, 2006 | 09:32 AM
Venomous S's Avatar
Default Profec e01 and EMS
I did search but could not find anything as far as if the Profec e01 can be used with the EMS for just a boost controller so this way you don't have to tap into the EMS via laptop. You could just adjust max boost via the screen on the fly...???
I dont' see why it can't be used except I am not sure about the pressure sensors. Obviously if I am using the EMS ECU I would most likely need the pressure sensor from EMS but how would I communicate to the profec using AEM's pressure sensor. Then again if this is the case, then the profec can not be used to control boost with the EMS...??
Old May 4, 2006 | 03:14 PM
blues2k3's Avatar
....you can use the profec e01 as a boost controller by itself. It does not have to be wired into the AEM. It will use the greddy solenoid and the map as a signal. Now the AEM reads boost/load also from the map sensor, but you are not controlling boost through there just getting reading/value.
Old May 4, 2006 | 03:35 PM
AROD's Avatar
i thought i told you this yesterday???
Old May 4, 2006 | 03:42 PM
blues2k3's Avatar
yo Arod, pick up your phone we gotta go to the track this weekend...she's ready!
Old May 4, 2006 | 06:43 PM
Venomous S's Avatar
you did partly
But I forgot to ask both of you's exactly what hardware works with what and didn't wanna call u guys again to ask.
Old May 5, 2006 | 02:53 AM
blues2k3's Avatar
ideally use a GM 3 bar map sensor if you are going with the AEM. You will also need a Greddy boost solenoid which should come with the Profec e01.
Old May 5, 2006 | 06:19 AM
Venomous S's Avatar
cool
thanks for the info
I am contemplating switching to EMS but not looking forwarding to the pricing.
kawi10r998cc
Jan 7, 2009 05:21 PM
CourageOO7
Feb 20, 2008 05:15 PM
ChefJ
Apr 24, 2007 07:47 PM
kinetica
Apr 5, 2006 06:10 PM
Silver S2k4
Jul 31, 2005 05:50 AM
