PTE 5431
Old Oct 22, 2010 | 08:59 AM
305s2k's Avatar
Default PTE 5431
Was doing a search for this turbo on here and I couldn't find any info on it. I would appreciate any info I can get regarding the following:
Spool up time...
What A/R to choose...
Log or Equal Length Manifold... (I want faster spool and heard a log would spool faster?)
Will it be able to hit 400WHP...
Dyno Sheets...
Or if anyone has another turbo to recommend me please let me know
I mainly want a turbo for autocross. I want something small with wicked fast spool and hopefully be able to hit 400whp.
Here are some specs for this turbo:
Manufacturer: Precision
Part Number: 5431
Compressor: Cast
Bearing Options: Journal Bearing
Model: 5134
Power Class: 480hp
Compressor Wheel Diameter: 54mm/70mm
Turbine Wheel Diameter: T31
Compressor Housing Options
* B Cover - 2 5/8"in/1 3/4"out
Turbine Housing Options
* T3 4 Bolt - .48, .63, .82
Old Oct 22, 2010 | 09:04 AM
DBXFX's Avatar
I'm not sure on the specifics but from what I've read, I would at least get a ball bearing vs journal bearing turbo if you want the best spool. Also, I believe the smaller the A/R, the better spool you will get. If you never plan on going for more horsepower, go with the smallest turbo that will put out a little more than your goal.
I'll leave the rest up to the pros. Good luck
Old Oct 22, 2010 | 11:17 AM
spectacle's Avatar
The downside to ball bearing turbos is they are not rebuildable. If you burn one up, you have to replace it.
Old Oct 22, 2010 | 01:01 PM
Suzuka_Joe's Avatar
You don't want a log. A 5857 ball bearing spools really fast. I hit 422whp with 13psi with mine
Old Oct 22, 2010 | 05:19 PM
305s2k's Avatar
True, but I also dont want it to fall flat on top because of the small A/R
Old Oct 23, 2010 | 07:19 PM
305s2k's Avatar
Anyone with some info?
Old Oct 24, 2010 | 07:14 AM
Deception's Avatar
I dont think you will hit 400whp with that turbo unless you run a lot of boost.
Its max is 480 at the crank.
Get the 5857 Billet, JB or BB depending on your budget
Old Oct 24, 2010 | 07:27 AM
Suzuka_Joe's Avatar
5857 ball bearing only. Journal bearing precisions die due to the f2x super high oil pressure. We even have to run 2 restrictors on the ball bearing ones to decrease how much oil gets to the turbo
Old Oct 24, 2010 | 08:39 AM
Deception's Avatar
I ran a .062 restrictor on my JB and its fine
Old Oct 24, 2010 | 09:38 AM
dsddcd's Avatar
Spool up time...
Dyno Sheets...
Part Number: 5431
Compressor: Cast
Model: 5134
Power Class: 480hp
Based on your wants assuming you have the turbo kit, motor and tuning to back up the 400HP goal, I would say you will probably want something smaller than a 5857 but larger than the 5431. I would take a look at a something in the GT2876R with T3 flange and a .82 AR.
As for the manifold, if you are DD the car also I would stick with a bottom mount and my (2) choices are the IP Street Kit and the Ptunning kit. Since you are autocrossing the car I would suggest that you look for an ELT so that you can build low end torque.
Here is a torque graph of the (4) setups on my car for reference.
Torque Curves
