Pulley adjustment
Well I got the base map, tuner started to tune, got to 7K and the SC belt shredded. It looks like the idler and sc pulleys are not lining up. The SC pulley is about 1mm backward of the idler pulley. Is there a way to adjust the alignment?
We thought of a spacer, but it would have to go on the idler pulley and that doesnt seem like the best solution.
The SC pulley was on backwards and was off by a good half inch. We flipped it and then it was off by only a mm.
But dont worry, we found the problem...the tech put a washer behind the tensioner pulley. Removed that and now I am tuned.
the pullies on the mount plate only go on one way. Sounds like your SC pulley is backward.
