Pulley Change - How to?
Old Jul 8, 2007 | 05:42 AM
mikey k's Avatar
Default Pulley Change - How to?
OK I'm sure I'm missing something here!
I have a 3.625" pulley and belt to upgrade my Comptech SC & AC setup.
The pulley has the key slot same as the OEM crank pulley.
I presumed you swap the OEM pulley off, along with the Comptech pulley which is bolted on the front of it.
Then it occured to me I would then only be able to run one belt, rather than the two that are on now (Comptech SC & OEM serpentine).
That confused me!
I did some searching, checked the FAQ & DIY threads, read the workshop manual and the Comptech instructions.
Then I released there is a pulley on the back of the blower.
So the question I have is when you do a pulley change for more psi do you change the crank one or the blower one?
If you change the blower onewhat torque do you use to tighten it?
Old Jul 8, 2007 | 06:24 AM
GoFaassttt's Avatar
Change the blower pulley. You will need to have the car re-tuned.
Old Jul 8, 2007 | 06:33 AM
mikey k's Avatar
I thought I was missing some thing!
I've also got some 750 injectors and an AEM EMS to fit before I let Mase lose on it!
Old Jul 8, 2007 | 06:41 AM
Sideways's Avatar
You don't change the crank pulley. Just the pulley on the supercharger.
I just tap it down with three or four hits of the pneumatic wrench. The pneumatic wrench also helps with the removal of the bolt.
Old Jul 8, 2007 | 12:54 PM
OyATL's Avatar
Locking pliers will also help you get the bolt off the blower pulley more easily. There is no need to take the blower out the car. Just loosen the 3 main bolts on the supercharger bracket just enough so the pulley has room to slip off. Use the locking pliers on the pulley along with a wrench on the bolt. A breaker bar will also help you loosen the bolt fast. Don't lose the little key or you are screwed. I retightened the bolt hand tight with just a little extra nudge with the breaker bar.
Old Jul 8, 2007 | 11:55 PM
mikey k's Avatar
Cheers guys
I think I'll take it out to do it as I'm doing the clutch, header and radiator at the same time anyway
Old Jul 9, 2007 | 08:17 PM
CKit's Avatar
I used the old belt to hold the old pulley in place while I loosened the nut.
Old Jul 10, 2007 | 12:16 PM
mikey k's Avatar
Good plan!
Old Jul 10, 2007 | 01:17 PM
markS2kcU's Avatar
I give the spanner a sharp blow with a BFH whilst the belt is sill on and has tension on it, always worked for me.
BFH FTW.
Old Jul 10, 2007 | 01:31 PM
mikey k's Avatar
BFH
macdaddies911
May 13, 2014 08:30 AM
s2kadrenalin
May 14, 2011 07:50 PM
erikvanden
Jun 29, 2010 08:01 PM
NFRAP1
Socal Swap Meet
Apr 30, 2008 12:27 PM
Headchef
Sep 5, 2007 06:49 PM
