purge valve vacuum
Old Aug 8, 2012 | 02:25 PM
Phill24's Avatar
Default purge valve vacuum
i have a newly found vacuum leak...not sure if this is the cause of the leak
My link
number 6..purge pipe..both ends was connected to the intake manifold but on the bottom where it split there is a hanging hose with a clamp around it like it was connected to something....can any1 tell me what it's suppose to go to?
Old Aug 8, 2012 | 02:56 PM
Forcedbird's Avatar
I believe it goes to the purge valve which is bolted to the frame in the engine bay located on the driver's side.
see here:
http://www.hondaautomotiveparts.com/...SOLENOID+VALVE
Number 11 where in the pic it's not connected to anything.
herecomesboost's Avatar
I completely removed those hoses (used vacuum plugs on the IM). They are part of the purge/pressure relief system.
Old Aug 8, 2012 | 03:19 PM
Phill24's Avatar
Ok imma remove them from the manifold then
Old Aug 8, 2012 | 03:20 PM
Is emissions testing required where you live?
Old Aug 8, 2012 | 06:59 PM
Phill24's Avatar
Yea...forgot about that
AP1Driver
Jun 5, 2012 07:15 AM
S2kAndTheAnt
Apr 26, 2010 01:21 PM
MuckaLun
Feb 18, 2008 10:31 PM
