Question on -8 and -6 fuel lines..
Old Aug 11, 2012 | 08:18 AM
#1turbos2k's Avatar
Default Question on -8 and -6 fuel lines..
So am almost done with my fully built s2k and now the last thing i need is to run my stainless steel braided fuel lines. I have the dual hanger from fullblown and i just cant seem to pass the lines from the hanger to the bottom of the car so i can run them to the front of the engine. it seems like there is no space between the tank and the alluminum around the tank without the lines getting crimped ? any pics or suggestions on how people are doing this ? thanks
Old Aug 11, 2012 | 08:21 AM
Corey Maurer's Avatar
I did mine up from the bottom, fed through just fine
Old Aug 11, 2012 | 10:21 AM
#1turbos2k's Avatar
from which side of the tank? towards the engine side of the tank or from the rear of the tank towards the diff ?????
Old Aug 11, 2012 | 11:37 AM
Engine side, right where the stock lines ran
Old Aug 11, 2012 | 03:15 PM
Phill24's Avatar
When i did mine i ran it towards the driver side of the car i had to bend the lip on the tank to get them to clear
Old Aug 11, 2012 | 03:19 PM
#1turbos2k's Avatar
Corey, phill:::: did you had to remove the stock fuel lines in order to make the new lines fit ?
Old Aug 12, 2012 | 05:14 AM
I'm not sure if I needed to because I removed mine before I installed the braided
Old Aug 12, 2012 | 06:41 AM
passmans2kny's Avatar
i removed the stock lines first but you should be able to feed up the new ones from the bottom either way, put a light by the hanger top to help guide you from the bottom
Old Aug 13, 2012 | 10:36 AM
Phill24's Avatar
left mine in just incase i decide i want to put the car back to stock...i'll more than likely remove them this winter
06RioS2
Sep 22, 2014 07:36 PM
#1turbos2k
Aug 16, 2012 05:32 AM
FullBlown
Nov 24, 2011 07:35 AM
airwalk07143
Sep 23, 2008 09:13 PM
millertown15
May 8, 2006 06:20 AM
