Question about AEM Wideband Installation
Everything is set, i just need to find a place to get that giant jack plug through the firewall so i can connect it to the sensor. do i have to drill a hole somewhere or is there an open 1.05" spot that it will fit through?
Also, I'm having a O2 Bung Welded in the test pipe next week, any suggestions on where to have it installed at?
Thanks guys.
Thanks guys.
I used a wire coat hanger, duct tape, and silicone spray lube. Just duct tape it up so that you don't put any strain on the wires connecting to the connector. It slides in really nice using silcone spray.
Placed on mine on the header a few inches before the cat...ran the wire up through the wheel well ( can't see it ) behind the battery, drilled a hole in the firewall next to where the battery would be ran it through and hinged the plastic panel where your obd2 input is...and now the gauge is mounted on the plastic panel and swings up and down when I wish it to so I can see the gauge or hide it
also I used some outdoor caulking around the wire through the firewall hole keep out any dirt or water.
Hershey
Sep 23, 2014 06:32 AM
