Question about Inline Pro Headgasket Install
Old Dec 17, 2008 | 08:30 PM
neeman77's Avatar
Default Question about Inline Pro Headgasket Install
Hey guys,
I am installing my 3mm headgasket and I just go to the point where I am re-installing the timing chain tensioner. Even before the TCT is seated there is resistance from the guide and I can see it though the access hole. Is this normal, should I force the TCT in and bolt it up?
Also I followed the honda manual for torquing the head studs (OEM), does anyone have a value I can set my torque wrench too to check if they are sufficiently tight? The 90 degree business leaves me uneasy. Thanks!
Neema
Old Dec 17, 2008 | 08:35 PM
AusS2000's Avatar
If you used proper assembly lube the 90 degrees method will be fine. I have no idea what torque setting that is equivalent to.
As for the chain, it is tight isn't it. Had me worried but I assembled as per the manual and have had no problems.
Old Dec 18, 2008 | 10:06 AM
fuel4blood's Avatar
If you look in the forced induction faq you'll see theres a thread talking about this. They mention clocking the cam sprockets let me get you the link.
Old Dec 18, 2008 | 10:10 AM
fuel4blood's Avatar
Turbo FAQ
Here's the link
Old Dec 18, 2008 | 10:57 AM
neeman77's Avatar
Yes I did the cam sprockets, I was wondering about the tension on the chain which seems excessive. I read that it would be tight, but I did not think it would be THAT tight.
Old Dec 18, 2008 | 12:07 PM
Soul Coughing's Avatar
did you fully compress the TCT before reinstalling it?
Old Dec 18, 2008 | 12:11 PM
AusS2000's Avatar
It's tight before you even install the TCT.
Old Dec 18, 2008 | 09:29 PM
neeman77's Avatar
Yep that is what I experienced, I did compress the TCT first. Thanks for the reassurance to push in the tensioner into the head lol...
Old Dec 19, 2008 | 08:40 PM
Kirpich's Avatar
I bought the 3mm Cometic, and couldn't install it. It was so tight that I knew it would just rip the timing chain, destroying the engine.
So I call the guys who sold it to me through Ebay, and guess what they say: Go ahead and have a machine shop shave the head down. !!! that defeats the point of raising the head above the deck!
Long story short, it almost came to a lawsuit, and finally they took the 3mm back and gave me a 2mm. Now I got the 2mm and it's fine.
I wouldn't risk 3mm on my ride, it was that tight. I know a lot of ppl running 3mm by InlinePro, maybe it's a hair thinner, but Cometic one... I didn't risk it.
Old Dec 20, 2008 | 06:17 PM
03silver2000's Avatar
...inlinepro 3mm headgasket is made by cometic, you guys must have installed in wrong or something, mine went No problem.
