Question about Kpro
Old Jul 27, 2013 | 02:01 PM
s2kiono's Avatar
Default Question about Kpro
I have an AP1 and will be installing kpro along with all the upgraded parts/sensors/valve cover. my question is, if i were to go back to a stock ECU in the future, will all these sensors have to be taken out and replaced with the original or will the stock ECU run fine?
Old Jul 27, 2013 | 07:02 PM
timg's Avatar
Everything has to come back out.
Tim
Old Jul 27, 2013 | 08:03 PM
s2kiono's Avatar
Tim
can anyone confirm this?
does everything have to come back out or some can be left in?
Old Jul 28, 2013 | 02:58 AM
jaundice's Avatar
Everything has to be replaced with AP1 OEM sensors for OEM AP1 ECU to work. You are putting AP2 06+ sensors in for the KPro and the AP1 ECU cannot read those. The crank wheel and sensors are different, and the KPro/ 06+ only uses exhaust cam sensor (which is different) and the AP1 ECU uses exhaust and intake cam sensors. It is all very different and NOT interchangeable.
Old Jul 28, 2013 | 08:42 AM
sohc_mshue's Avatar
Or....you could run a plug and play standalone that is way better and requires no swapping sensors. Unless you need this to pass emissions.
Old Jul 28, 2013 | 09:26 AM
s2kiono's Avatar
which standalone are you referring to?
yes i need to pass smog, but from what i found, another s2ki member did pass smog with kpro but it was throwing different codes to the tech(possibly saying its an rsx?)
has anyone passed smog with kpro in california?
Old Jul 31, 2013 | 01:24 PM
spectacle's Avatar
AEM, Haltech, or Pro EFI
None will pass emissions, but all are PnP (I think Pro EFI might need a harness)
RWDlover
Sep 22, 2015 05:26 AM
kokuwow
Mar 10, 2013 12:11 PM
niick
Nov 9, 2012 01:19 PM
