Question for DD meth heads
I start spraying at 5psi and 1 Gallon lasts me 1.5 months or so, granted if I am going to a meet or osmething I tend to get Boost happy, but shortest I have ever had to refill was like 2 weeks
550cc nozzle (largest)
the 550cc nozzle in theory should work out to 550ml/minute
but this must not be the case if it is lasting this long.
For example.
1 gallon is approx 4l
550ml/minute
= 7.3 minutes at full throttle, which I assume from what everyone is saying you are getting much more than this? Or are you just not full throttle very often?
I'm trying to run just water/meth as my IC and want to make sure have enough for 20 minute track sessions.
Thanks for the help!
For example.
550ml/minute
For example.
550ml/minute
For example.
550ml/minute
your not always spraying is what im saying.
Unfortunately don't have any data as still building this car, but the data from our NA Super Touring IS300's shows TPS at 100% for at least 50% of a lap, and I would assume over 5 PSI boost for at least 70%.
This is what I was working from before and figured a 3 gallon would be necessary, but I'm wondering if the 550cc is actually flowing 550cc with the pressure the pump runs.
tidalwdave
Apr 5, 2004 02:18 PM
