Question on ID1000s ...
Old Jul 7, 2012 | 05:25 AM
Reapur's Avatar
Default Question on ID1000s ...
What's the difference between ID1000s for my00-05 and 06+??? And can the ones for 06+ be used on the older model years with some kind of modification ?
Old Jul 7, 2012 | 06:31 AM
Ryuu's Avatar
if your asking about injectors.. I don't believe there's anything different for any model year... they're all useable... if not... idk what your askin bout...
Old Jul 7, 2012 | 07:45 AM
99SH's Avatar
The seal arrangement and fitment are different. See below, MY06+ on the right
Old Jul 7, 2012 | 07:50 AM
Reapur's Avatar
Damn doesn't even look like it can be made to work
Old Jul 7, 2012 | 08:09 AM
Ryuu's Avatar
I see that... owning an 01, hadn't ever looked at 06 on up but as per many of the ad's for parts, they all treated them as more universal, listing them as 00 - 09 usually... after looking more for 06 on up, I see product differences... concept staying the same an all..cool, thanks, didn't know...
Old Jul 7, 2012 | 08:20 AM
donaldmejr's Avatar
My id1000's look like the ones on the left and I have a 2008 but also a inlinepro return fuel kit.
Sent from my HTC PH39100 using Tapatalk 2
Old Jul 7, 2012 | 11:07 PM
s2000Junky's Avatar
The 06+ are pictured and can be modified by ID for 00-05 or do it yourself. I Ended up taking a Dremil and carefully grinding down the plastic housing and then replaced the large o ring with the stock size and fit into thew 00-05 fuel rail perfectly. I wouldn't recommend this mod unless you are proficient with detail Dremil work. I reluctantly did it because I was too impatient to send to ID to have modded.
Old Jul 8, 2012 | 07:36 AM
DFWs2k's Avatar
Or you can use an 06+ fuel rail or modify an 00-05 fuel rail
Old Dec 5, 2012 | 06:58 AM
AFs2k's Avatar
Why didn't you call injector dynamics? (I lied)
Old Dec 5, 2012 | 07:15 AM
spectacle's Avatar
Why are you asking redundant questions to threads from July?
