Question using AEM EMS
Old May 25, 2012 | 02:43 PM
s2kseven's Avatar
Default Question using AEM EMS
I supercharged my s2000 engine and now using AEM EMS
This is a racing car not Honda s2000 chassis. Before my supercharging, I used the stock Honda s2000 ECU.
I welded 2 bungs for PRE-POST 02 sensor. Now that I'm using AEM EMS, can I delete my PRE & POST 02 sensors?
In other words, is the AEM EMS using the 02 sensor? Will I get a CEL if I delete it?
Thank you
Old May 25, 2012 | 03:13 PM
RacerXI's Avatar
You won't get a CEL unless you set it up to trigger it. The AEM doesn't offer it for engine codes. You can remove the post 02, but you'll need to keep the pre 02 or run a wideband. If you remove both, how will you monitor the 02 readings?
Old May 25, 2012 | 03:54 PM
teamvalorracing's Avatar
yeah, remove the oem sensors and run an aem wideband sensor to your ecu. you dont even need the whole aem uego gauge controller simply to supply signal for the computer.
GaryRudolph
Mar 5, 2012 10:56 PM
skool u
Jun 23, 2010 10:46 PM
afwfjustin
Jun 17, 2008 10:05 PM
ITBs2k
Nov 12, 2006 09:05 AM
Spoolin
Jun 22, 2005 04:53 PM
