Rev Hard Kit
Old Mar 26, 2009 | 11:49 AM
slicko9's Avatar
Default Rev Hard Kit
I am thinking about buying the rev hard kit and upgrading to the gt30 turbo..
i am going to use K-pro to tune it and go from there.
anyone that has that kit, do you like it? pros cons? alternatives for comparable price?
thank you
Brian
Old Mar 26, 2009 | 12:53 PM
busterpit23's Avatar
I've had a revhard cast manifold as part of my custom turbo kit before. You can make some decent power more than a greddy kit but you will have to run a very high amount of boost to see midrange #s like 400rwhp. Look at the 300-350 as a relistic power output for this kit.
I personally would save an extra $1000 and go with inlinepros castmanifold setup over the rehard. It will be more a little more efficent, higher quality parts, and has a lot more options for you down the road depending on how much power your looking for.
Old Mar 26, 2009 | 06:14 PM
slicko9's Avatar
i am still going to street drive the car, i am looking for some where 300 to 350, i am also doing this on stock block.
Old Mar 26, 2009 | 07:30 PM
s_d2k's Avatar
why the inline cast manifold is more efficent than the rev hard manifold?
i see a lot of projects with inline cast that make amazing numbers , so why it should be any diffrent with the rev hard?
and lets say that all the other parts like turbo/injectors/ems are simillar on both.
Old Mar 27, 2009 | 07:05 AM
ya@inlinepro's Avatar
Our cast manifold has bigger ports than the revhard.
Also a centralized waste gate port helps with boost creeping/spiking issues as well.
And lifetime warranty. Still have yet to see any of our cast iron manifolds break, whether it be the s2000 or the B Series manifolds.
Old Mar 27, 2009 | 07:07 AM
btstone84's Avatar
inline pro manifold will help you make way more power than the motor is capable of
Old Mar 27, 2009 | 10:28 AM
JDM_EM1's Avatar
im running the revhard manifold, i think its a great piece for the price. i've been running it for 25,000 miles now not one problem. honestly i don't think its that much different than the inlinepro manifold. i say that cause im actually running the inlinepro downpipe. it bolted right up with no modification. im making 375hp @10psi. check my sig for the full setup.
05-tsx-or
Apr 1, 2010 07:54 PM
S2000Tuner
May 14, 2009 05:24 PM
mwbs2k
Dec 28, 2005 03:59 PM
Enthusiast
Nov 10, 2004 11:44 PM
DB-350ZTRACK
Dec 19, 2003 09:21 AM
