Reverse rotation of the turbo?
IS BAD.....for the most part....if you ahve a turbo that flows ONE way....which is the way that its supposed to in order to force air, its not meant to go the other way. thats why if you ever hear a blow sound like....... vrrooOOOMM PSSSSSSHH...thats good....and unless you got one of those funny blow off valves...and it goes vrrroOOOM PSH ch ch ch ch.....that means the air is going back into the turbo and causing it to "chop" and stop the flow of the turbo and can kill it......fairly quickly on some cases.
Or if you go in reverse.....your turbo will go in reverse to pull you backwards hehehehe..
