revhard manifold bolt question
Old Apr 7, 2010 | 10:45 AM
Deception's Avatar
Default revhard manifold bolt question
I got some major boost leakage last night.. looked around and noticed 1 of the 4 bolts that hold the turbo onto the manifold is gone, and a second one is very loose.
they are the two that are closest to the front of the motor
Need to fix this asap & will only have limited access to another vehicle after work for buying bolts & whatever else
Can you get in there with one of those stubby ratcheting gear wrenches?
Or am I going to have to remove the manifold etc? I have a complete tool set otherwise, any tips?
thanks
Old Apr 7, 2010 | 11:10 AM
Suzuka_Joe's Avatar
A normal 12mm wrench should get to the front 2 bolts
Old Apr 8, 2010 | 09:48 AM
Deception's Avatar
i wish.. it turned out to be a real PIA.
I was able to get the bolt closest to the engine on using a really short 17mm open wrench. Had to have my friend hold the wrench on the bolt from under the car while I actually turned the wrench from the top of the motor.
The bolt that was loose is stuck between the oil feed flange & the rest of the turbo, it aint moving unless we take everything off the car.
Some im still leaking boost, but its not as bad. Can hit a full 9psi, but it gets harder to do so in the higher gears.
Im going to be taking everything off next week & using ARP studs/bolts all around, and then tack weld the connections just to be safe. I think my 3" DP is the cause, it needs a flex section. I never had a single bolt back out in 7 months when the 2.5" DP was on the car.
Old Apr 8, 2010 | 09:58 AM
dsddcd's Avatar
I welded in a flex joint and a braket to bolt the DP to the block also and have had no trouble.
Old Apr 8, 2010 | 10:00 AM
Deception's Avatar
^^ Looks clean, Im gonna try that too
thanks
Old Apr 8, 2010 | 05:27 PM
pwrofdrm's Avatar
Definitely get a flex welded in. You might want to consider stage 8 locking fasteners for the turbo as well. They're about 30 bucks and you'll never have to worry about it again.
Old Apr 9, 2010 | 02:26 AM
P-CarDriver's Avatar
I have a flex, and the downpipe is bolted to my block and i STILL had the same problem with my RevHard manifold w/ARP studs and nuts.
I just routinely check them and keep them tightened. Eventually ill get the nuts drilled so i can just run safety wire through them.
S2K-OED
May 16, 2016 07:27 PM
skool u
Oct 5, 2010 08:48 PM
juntuned
Jul 27, 2010 04:56 PM
tej
Dec 8, 2009 12:20 PM
AndyFloyd
Mar 10, 2009 02:02 PM
