Running on 3 cylinders
Old Nov 29, 2014 | 04:07 PM
bagherra's Avatar
Default Running on 3 cylinders
Hi all,
It's been awhile and even though I've moved to racing/riding motorcycles but I still love my S. Unfortunately it (S2000 with SOS Stage 2) seems to be under the weather.
It acts like it is running on 3 cylinders, but it's intermittent.
Replaced:
1) Spark plugs
2) Primary O2 sensor
3) Coil packs
Added:
1) Injector cleaner
2) New gas
All of the above have improved how it runs, but it still is running a little low on power.
I was considering replacing the Map sensor next (still stock) and then looking into potential injector issues.
I welcome tips/suggestions. Is there something else I should look into?
Old Nov 29, 2014 | 04:21 PM
liquid_helix136's Avatar
What injectors are you using? The id injectors pnp harnesses are notorious for failing and causing a misfire
Old Nov 29, 2014 | 05:37 PM
camuman's Avatar
X2. I would look here first.
What engine management are you running? Log and you should be able to see a bit of what is going on.
Old Nov 29, 2014 | 10:58 PM
indi00's Avatar
Quick and dirty way to see if it is an injector/harness problem is to have the car running. Remove injector plug #1. The engine should run a little rough. Plug back in the harness and the engine runs normal again. Repeat step for injector 2-4. If it is a injector or harness issue, you'll know because removing the injector plug will not affect how the engine is running.
Was on 3 cylinders before due to a injector harness issue and the car was idling rough and noticeably sluggish. Fix the injector pin and everything was back to normal.
Old Nov 30, 2014 | 05:37 AM
bagherra's Avatar
Thanks for the replies/thoughts. AEM is the engine management system and RC Engineering Injectors.
I did the unplug/replug process for all 4 injectors and it ran a little rougher than the usual rough for all 4 when unplugged.
I'll look into how I can pull a log from the AEM.
Old Dec 1, 2014 | 07:52 AM
EOE's Avatar
EOE
If it was running on 3 cylinders you'd sound like a Subaru and have no power. In your case sounds intermittent, hmm.
Old Dec 1, 2014 | 09:46 AM
SeanGPW's Avatar
Just do a compression test to check:
http://www.autolifers.com/how-to-diy-compression-test/
blinktodd
Mar 6, 2015 02:17 PM
jamie.1986
Feb 25, 2015 08:29 AM
I_s2k1
Jun 9, 2013 04:49 PM
jb34304
Nov 2, 2010 08:36 PM
Turbocanon
Jun 11, 2007 03:28 PM
