running too rich
Old Apr 17, 2011 | 12:36 PM
s2k16803's Avatar
Default running too rich
I have a fully built turbo motor running on aem 1052... When I had the car tuned it was winter but shortly after I moved to florida so now the car is running overly rich. So I was wondering if there is a simple way to pull some fuel or if I can set an afr that the program will auto correct the fuel map to? Thanks for any input.
Old Apr 17, 2011 | 02:31 PM
Blucky87's Avatar
Check ur ait fuel trim if your not using o2 feedback
Old Apr 17, 2011 | 04:23 PM
s2k16803's Avatar
I have 02 feedback on... it helps with cruising but when I go WOT my afr goes to 10.5 or lower.
Old Apr 17, 2011 | 05:10 PM
Blucky87's Avatar
Does 02 feedback turn off when you go WOT? if it does you need to adjust your ait fuel trim
Old Apr 17, 2011 | 07:39 PM
spectacle's Avatar
Contact my tuner Alpha - tuning@inductionperformance.com. If you're in FL, he can help you
bois2k
Jun 22, 2018 08:09 AM
nMeOnE
Jul 11, 2017 03:20 AM
Erajk
May 26, 2016 09:38 PM
DFWs2k
Oct 23, 2010 11:40 AM
Rieger328Ci
Oct 28, 2002 08:16 PM
