s/c spoon engine?
Old Jan 12, 2006 | 03:24 PM
S2k BF's Avatar
Default s/c spoon engine?
Hi guys, i currently have an s2 with complete spoon engine cams, valves etc. i also have spoon exhaust and ecu and was contemplating a comptech supercharger + a/c and was wondering what sort of performance to expect?
would be grateful if you could shed some light on the subject?
Many thanx
Ben
Old Jan 12, 2006 | 11:01 PM
JAMESDEAN65's Avatar
expect to be buying more tires
Old Jan 12, 2006 | 11:09 PM
WyattH's Avatar
Well the Comptech kit in stock form on a stock car puts down about 280whp I reckon.
I think your Spoon engine is putting down about 225whp.
Stock is 200whp.
So, you can expect anywhere from 290-310 whp I would assume.
I am not sure how exactly the Spoon internals will work with the SC, but Im sure they wont hurt performance.
BTW - please shed light on your Spoon cams? I was unaware they made some?
Cheers!
Old Jan 13, 2006 | 12:49 PM
S2k BF's Avatar
Sounds good!
The spoon cams are really good they made a big difference to the torque and feel of the throttle! definitely worth an investment!
am very satisfied with the spoon engine, have a friend with an evo 6 and keep up with him ok, you reckon the s/c will be enough to push past him?
Old Jan 13, 2006 | 03:16 PM
CrazyPhuD's Avatar
Probably a bad idea with the spoon ECU being the worst choice as far as SC the engine goes. Whythe spoon ecu is targeted for max NA performance, as a result the ECU will lean out the mixture more than a stock ECU. Put a stock SC on with and ECU that's running leaner than the the SC is designed for is a recipe for detonation.
Also you're running at least 0.7 points of higher compression(if it's true spoon). Increasing compresison + FI = recipie for detonation.
Finally at best the cams + FI will have minor performance impact, at worst they will provide a significant performance decrease. The design differences for Max NA power cams and FI cams are significant.
if you want to go FI sell the spoon engine, get a stock one and use the money difference to fund the SC kit.
Old Jan 15, 2006 | 09:09 AM
S2k BF's Avatar
is there no way of supercharging a spoon engine?
i take it its the same story for a turbocharger?
Any thing else you recommend to get big whp?
Old Jan 15, 2006 | 01:40 PM
WyattH's Avatar
I agree with Crazy above... He's right about it all - I overlooked it.
Youll want a different ECU for the SC, and whats good for NA is not always good for FI.
But you should be able to find a local to swap engines + cash that will buy you the charger.
If you are tied with an Evo6 now, youll own him when SCed.
Old Jan 16, 2006 | 08:31 AM
S2k BF's Avatar
Am not really keen on swapping the engine!
Is there anyway of keeping the block and changing to 2.2 bottom end aem ecu and different cams with s/c?
would that work?
Old Jan 16, 2006 | 08:37 AM
WyattH's Avatar
You could probably retain your cams.
You can buy a 2.2L stroker crank (big bucks). And of course an AEM EMS will always help assuming there is a reputable tuner near you.
Old Jan 16, 2006 | 10:28 AM
S2k BF's Avatar
Have been looking at the toda 2.2 stroker kit and that increases compression to 12.7 : 1 is that acceptable for FI or too high cos i havent got a clue!!!!
