s/c spoon engine?
Old Jan 16, 2006 | 11:06 AM
Trip's Avatar
Originally Posted by S2k BF,Jan 16 2006, 09:28 PM
Have been looking at the toda 2.2 stroker kit and that increases compression to 12.7 : 1 is that acceptable for FI or too high cos i havent got a clue!!!!
That would be an overkill IMH
with a 12.7:1 CR and a standard S/C boost of 5.5psi will get you an effective CR of around 17.5. This will be equal to a standard 11:1 CR engine running around +9PSI.
If you do a search there is a well expained thread about Low CR + High Boost engine VS High CR + Low Boost engine
Old Jan 16, 2006 | 11:11 AM
Trip's Avatar
here you go
https://www.s2ki.com/forums/index.php?showtopic=336991
Old Jan 16, 2006 | 01:24 PM
S2k BF's Avatar
excellent thanx for the info!
am told that the spoon engine compression is 12.1:1 so the stroker would give the engine a higher compression!
I think am going to swap the ecu and run about 7 p.s.i. that works out about 17.7 effective CR?
Old Jan 16, 2006 | 03:05 PM
Trip's Avatar
If you want to enter the F/I world, I suggest you sway to a standard engine and get a stock S/C to start with.
If you had to boost the spoon engine you will need at least a standalone engine management, larger injectors and a proper FPR. You will need to tune the car too..
You have to ask yourself if there are good tuners nearby who is able to tune it for you ?
Old Jan 16, 2006 | 03:49 PM
WyattH's Avatar
The only system that wont "need" tuning is the basic out of the box Vortech and Comptech.
I would NOT consider raising the compression if you want FI at all. It's cheaper (and "better") to raise the boost than the compression. GL.
Old Jan 17, 2006 | 07:14 AM
S2k BF's Avatar
What size injectors would you recommend?
My engine has spoon injectors on already but am not sure what size!
Old Jan 17, 2006 | 07:25 AM
Trip's Avatar
Don't quote me on this but if am not mistaken spoon injecotrs are same like stock = 360cc
550cc or above will be good... but you still need some type of management to control them.
Old Jan 17, 2006 | 10:37 AM
WyattH's Avatar
Stock injectors will be fine for 7psi. If you raise to 9+ youll need bigger injectors. The more PSI (air), the larger injectors (fuel capacity) youll need. And with any injectors larger than stock, you need to tune.
Old Jan 17, 2006 | 02:16 PM
S2k BF's Avatar
Theres a good tuner in the uk that was mentioned in the uk forum!
Do you know where i can get a cheap aem ems?
Cheapest i have seen is around $1500?
Old Jan 18, 2006 | 11:23 AM
S2k BF's Avatar
Thanx for your input guys!
I will keep you posted on how the project comes along (and probably have some more questions!! Lol!!)
WVT
Nov 30, 2005 08:37 AM
BS2000
Sep 11, 2005 07:59 PM
chamich
Aug 26, 2003 08:43 PM
