S2000 Cr Turbo Advice
Ok so I am looking to turbo my 2008 cr and am really interested in purchasing Mase's Kit. From peoples experience how is this kit and what else will I need to purchase for my s besides this kit. ATM I have a stage 5 racing clutch and light weight flywheel sitting around already, so besides the clutch what else will I need? Can I run this on the stock exhaust? i will most likely swap out the rear at some point but is it needed right away with this kit?
I would highly recomend that you look into a PTuning kit if you are looking at Mase's. You can read some of the detail on my build thread as well as many recent threads with the kit with respect to it.
Best of luck!
Best of luck!
yup i was looking at mase kit, however i wanted a kit i could find the guy if i had a issue! mase harder to find then the cia sometimes, i called emailed waiting few weeks, never did get a call back or a email. but ptuning kit is solid. check them out if you have issues getting hold of mase, plus feb they running a sale on the kit.
Thanks for the advice, ill def take a look into those other 2 kits as well. Also for which ever kit i do go with will changing the breaks be needed right away?
Drew
Drew
