S2000 Supercharger
if you're looking for na power, the compression ratio of the motor will handicap you when you go boost. My suggestion for the motor would be to fix it when /if it breaks as these are stout with a proper tuner and mods
Makes sense. I've seen these engines to be extremely robust at handling insane power. I emailed LHT about their thoughts on this and they told me to not waste my money.
I know it's feasible to push 800whp out of this motor. Just need someone willing to get the SC set up.
Even hitting that goal with a TC stock s2k is no easy task, that video your talking about is pretty much the only one I have ever seen, or they dont last long enough to tell the tale. Mechanical expertise AND Tuning Expertise both play a very big role in how much you will make as well, if one side is lacking the overall potential will fall short.
I was gonna say something along these lines as well. Not sure how determined you are, and or I wouldnt feel right trying to limit your "goal" it sll comes down to you and what you want out of it. Lots of thought and supporting mods will have to be adressed though, start their and work your way to the end. I usually try to back plan and think through every step, this might help as well. I think displacement will be a big determining factor though as the highest stock is only 2.2l. a big thing you might be overlooking is you cant compare a Turbocharger to supercharger. which is what your doing right from the start. Yes #'s are #'s but they behave and all around designed to cater to two totally different power bands. I think you would be very surprised though and happy with anything under that goal, if you wanna big # SC'd S2k, very respectfully and not to be a dick but 800whp on SC'd stock S2k is a pipe dream IMO... GL
I wasn't meaning to compare the two, I just would LIKE to hit the same whp goal. I'll be more than happy with anything more than 500whp honestly, but I just wanna see what's possible. I have many big ideas for multiple S2k projects. She's my dream car.
I would advise against the NA stroker build n then going FI with it. From the start, if ur gonna stroke an boost I would deffly let the builder know u plan on SC'ing or going FI down the road. It's not just about compressions. I would also seek sum1 that has reputation with these builds for ex. IP I think has pretty good success with these applications.
