S2K:Round II
Originally Posted by MADjdm,Mar 30 2010, 09:40 AM
Looks good. The clearances are so tight with the PFAB kits
Everything, and I mean everything has to be spot on, or you run into major issues.
Even w/my 30r, I struggled with getting everything perfect.
W/g dump, oil feed/return, water lines, compressor clocking and downpipe fitment...
Oh well, part of the game I guess.
you and i both man..where did you have your gate dump routed? and also do you wish you can change discharge piping location? i do..
and also, did you soak your heat wrap in water and then do it? icant for the life of me get mine right..
I would change a good bit w/the manifold layout, but it doesn't matter now.
My next manifold WILL be a sidewinder style..so much more freedom to do things w/less restriction (in regards to space).
As for the heat wrap, no I did not soak mine..have never done it that way..but that doesn't mean mines right..I just know I've had great luck that way..I just pull it REALLY tight as I wrap it..and it takes several tries until it fits just right.
Originally Posted by Tech7427,Mar 30 2010, 11:51 AM
i was looking into low temp t stats and radiators.. do you like the mish?
i had one in my integra and i didnt have any problems
So my cousin welded 2 bungs on it for me for the turbo.
Now I have an oil-cooled turbo, so I just capped the bungs.
It seems to work the same as the OEM one..didn't see any big difference in temp drops, although I wasn't able to compare the difference as I didn't have an OEM piece and turbo.
Overall, it's a nice unit for the price as compared to other higher priced models, (koyo/etc).
