Safty with Comptech
Old Oct 25, 2005 | 07:32 PM
GotRPMs's Avatar
Default Safty with Comptech
I am soon going to purchase a comptech aftercooled sc kit for my 03' and i wanted to know if simply installing the kit had any adverse affects on the car. I read that some people were running lean post install on the vortech (i understand that this is a different sc) i just want to make sure that after the install the engine will remain safe for a daily driver. Also what kind of fuel milage can i expect post install?
Old Oct 25, 2005 | 07:40 PM
Sideways's Avatar
You ask the hard questions.
After the install have it dynoed with the AF ratio checked. This will let you know it is safe or not. If it is safe you will have many miles of smiles.
Your mileage is directly related to your right foot.
Old Oct 25, 2005 | 08:02 PM
GotRPMs's Avatar
So engine wise the a/f is the only real point of concern, have and new sc units experianced problems with this out of the box? Should the milage change from NA to sc though, i would think under vtec there would be litttle boost so milage wouldnt vary much.
Old Oct 25, 2005 | 08:12 PM
mega's Avatar
Old Oct 26, 2005 | 10:32 AM
spoiled@21's Avatar
i get 16-18mpg in boost through the mountains but still get 24-25 hwy.
Old Oct 26, 2005 | 11:05 AM
SIIK2NR's Avatar
Out the box your FPR should be set from Comptech. If you want to dyno it to be safe it's up to you. I know people who have done both.
Gas is adversely effected by 2-3 miles per gallon dependant on your driving style. Obviously if you are always on the gas...it will drop drastically. Normal cruising your gas mileage should be pretty close.
Old Oct 26, 2005 | 11:10 AM
Silver S2k4's Avatar
Old Oct 26, 2005 | 07:34 PM
PWRMKR's Avatar
I
Soopastank
19
Dec 4, 2008 10:51 PM
Axel6
13
Jan 16, 2006 08:16 PM
600rr_rocket
Feb 3, 2005 01:44 PM
eniety
Sep 6, 2004 03:04 AM
Daremo
Feb 5, 2002 09:43 PM
