?Saturated Injectors?
Old Jul 10, 2006 | 04:46 AM
PRS2K's Avatar
Default ?Saturated Injectors?
I had a set of RC P&H injectors on an Integra I had a few years back and I had to wire up a resistor box which was easy but not alot of fun I hate wiring.
Question that I was with saturated injectors obviously you don
Old Jul 10, 2006 | 04:57 AM
timg's Avatar
I had to purchase pigtails to wire in my saturated injectors. IIRC, they're all like that. I believe you can find adapter harnesses on the internet though.
Tim
Old Jul 10, 2006 | 05:36 AM
PRS2K's Avatar
Tim
So your saying just cut the 2 wire stock clips and wire in the new clips.
Old Jul 10, 2006 | 07:10 AM
Sideways's Avatar
Those of us in smog check land have made a separate loom with an 8 pin connector. Start by putting an 8 pin plug and socket in the stock setup and then make a new setup with the 8 pin and the 4 pig tails for the new injectors. Loom the wires into a piece of conduit like the factory wiring uses and wrap it up with black electrical tape so it looks stock. It makes going back and forth very quick an simple. I'd be sure to solder the connections and shrink wrap them for weather proofing.
Old Jul 10, 2006 | 08:45 AM
PRS2K's Avatar
Thank you!!!
I just bit the bullet and ordered the Inlinepro kit damn I can
Old Jul 10, 2006 | 11:52 AM
timg's Avatar
I just soldered in the new clips. I left the old clips on in case I had to do a smog check. That way all I have to do is pull the old ones and replace them with the new ones.
Tim
Old Jul 10, 2006 | 07:00 PM
f20kills's Avatar
automotivespeed.com
http://automotivespeed.com/product_i...roducts_id=151
Go here. I wish I had these when I did it.
ScienceofSpeed
Jan 14, 2010 09:21 PM
lotus7racer
Jul 22, 2009 09:51 AM
ex-eclipse
Mar 7, 2006 02:37 PM
my01s2k
Feb 20, 2006 09:03 PM
