SC:anyone running an intercooler?
Old Jan 17, 2006 | 07:49 AM
gusrock77's Avatar
Default SC:anyone running an intercooler?
...besides looking cool ...any benefit? ...any pics?
Old Jan 17, 2006 | 08:22 AM
xviper's Avatar
I take it you are talking about a "front mount intercooler". Most supercharged cars are running an "aftercooler" that is an air/water affair with a small radiator for heat exchange. Some guys will get a larger radiator that simulates a front mount intercooler for bling. It's still just a radiator.
If you're talking about a real FMI, this would eliminate the radiator and the air/water aftercooler. In this case, no, there is no benefit except for looks. In fact, the added volume inside the plumbing of such a device will actually reduce the boost pressure of the system. You'd have to increase boost at the blower just to get the same boost back to the intake.
Here's a pic of the "fake" one:
Old Jan 17, 2006 | 05:33 PM
gusrock77's Avatar
oh ok..thanks the input ...so the Tech2 is just a larger radiator? ...good to know
Old Jan 17, 2006 | 05:42 PM
xviper's Avatar
Yes, but don't let the size of it fool you. It actually holds less coolant than the stock Vortech or Comptech rad.
Old Jan 17, 2006 | 06:08 PM
r_duff's Avatar
really? i have the tech2 one. I compared the comptech and tech2 side by side, and i'd say the tech 2 will hold atleast 30% more liquid than the stock comptech unit (oounting % in terms of volume in the heat exchanger only, not piping, condenser, tubings).
Old Jan 17, 2006 | 06:09 PM
r_duff's Avatar
oh and btw, i think a puerto rican guy is running one.... 'eri s2' or something like that.
Old Jan 17, 2006 | 06:51 PM
xviper's Avatar
Putting the two side by side isn't a good way to determine the coolant volume inside. I drained and collected the coolant when I pulled the hoses off the old stock rad. When I got the Tech 2 rad installed, I could not get all the coolant that I drained back in. The Tech 2 may have a bigger exterior dimension, but the coolant tubes through the fins and the spaces on the ends do not have nearly the volume of the little stock rad. I had about 1/2 to 3/4 of a pint left over.
I noted the intake air temp using my ECU display last summer with the stock rad. Next summer, I can compare those readings with the Tech 2 rad in place.
Old Jan 17, 2006 | 07:58 PM
EriS2k's Avatar
Yes! Thats Me!
I'm Running the 10psi SOS pulley and FRONT MOUNT INTERCOOLER!
And on the dyno my boost is at 10psi, No loss of boost with the FMIC!
Old Jan 17, 2006 | 08:06 PM
EriS2k's Avatar
There ya go!
Old Jan 18, 2006 | 10:21 AM
Quivers's Avatar
Banned
anybody else have some input on this setup? Im looking into doing this.
