SC questions
Old Jan 20, 2007 | 04:41 PM
Jooboy's Avatar
Default SC questions
what type of gains does a SC give a stock AP2 with conservative boost? how many whp and at what rpms?
is 7 psi considered conservative or average?
if an s2k is supercharged (again, conservatively), what OEM parts will definitely need to be upgraded? i understand upgrading some components will optimize the benefits of the SC, but i'm asking more about safety/reliability/driveability issues.
Old Jan 20, 2007 | 05:26 PM
calaceyfl's Avatar
A stock Vortec or Comptec kit is 7lb. it gets you about 300rwhp. and its simply bolt on, so theres no parts NEED to be upgraded.
I see you have a 2006. I think there still working on SC for the 2006MY.
Also, the search option in your best bet. You'll learn alot.
Old Jan 20, 2007 | 09:46 PM
gomarlins3's Avatar
The new SC for the '06 is more expensive, but you will probably get more than the rest of us who stayed basically stock. I believe the new set up also gets an ECU reflash to gain even more HP. As stated above, there is no need to change anything else. The system is designed to work with all the parts that are on the car now. If anything else needs to be changed (FPR, fuel pump, etc.) it comes with the kit.
Old Jan 21, 2007 | 12:43 PM
mikey k's Avatar
I sold my 06 for an 05 so I could SC it with out paying
Old Jan 21, 2007 | 12:50 PM
Enthralled's Avatar
you might want to change out your spark plugs.also consider the clutch.
the only available kit for the 06 is Comptech.And yes they are already out...so i hear.
Old Jan 21, 2007 | 07:11 PM
TheCarGuy2021's Avatar
The stock clutch wasn't designed for the increased torque or power. You should probably invest in a clutch with a higher clamp load rating. If you don't, you may get some slipping at high RPM.
I'm still using my original clutch that came with the car and it still isn't slipping. Just trying to get as much use out of it before I NEED to replace it. When I do I will be upgrading.
Old Jan 21, 2007 | 07:15 PM
Enthralled's Avatar
I had to change out my clutch after about 6 months of having my Vortech installed.It started slippin' like a MOtherF.I wasn't driving like a fool but my guess is the CDV had something to do with it.
Old Jan 22, 2007 | 01:07 AM
Nick32's Avatar
comptech on 7psi for 4 months with 20k miles on my car and clutch started slipped REAL bad. had to put a new one in.
So id say clutch would be a smart investment
other than that thats all u should need. U could run i heat range cooler plug, but not necessary!
Old Jan 22, 2007 | 08:01 AM
mikey k's Avatar
This should answer you questions
https://www.s2ki.com/forums/index.php?showtopic=340163
Old Jan 22, 2007 | 10:43 AM
myclue's Avatar
Gold Member
nice
Vortech'd
Oct 7, 2008 04:32 PM
Akilldema
Jul 13, 2007 03:09 PM
batikan
Oct 22, 2005 12:05 PM
kstokell
Mar 10, 2005 04:21 AM
