SC with TP for spring install.
Old Feb 21, 2007 | 05:42 PM
lend_type_R's Avatar
Default SC with TP for spring install.
need advise. im planning to install my comptech SC and buy a 7psi pulley. and im planning to install my 70mm TP with the existing 70mm exhaust, is it neccessary to buy an wideband AF guage? coz from what i know if i have the cat installed the stock ECU will do its job with the 2 1/2 turn FPR. your help is very much appriciated.
Old Feb 21, 2007 | 10:11 PM
Spec_Ops2087's Avatar
Not necessary at all. However, what is necessary is to go to a dyno with an A/F recording device to make sure your A/F is in check (and adjust if need by). After its adjusted, no need to check your a/f really.
Old Feb 21, 2007 | 11:16 PM
gomarlins3's Avatar
I have the CT with 7 lb pulley, Rick's header, TP and CT exhaust. I found out I was running lean all the way through the power curve. Adjusting the FPR helped with everything below VTEC, but I need a VAFC to fix it above VTEC. I now have a wide band AF guage to keep an eye on things.
Old Feb 22, 2007 | 03:19 PM
which is better, take it to the dyno shop and let them have it tuned or buy a wideband and have an experiece mechanic(also a friend) do the tuning?
Old Feb 22, 2007 | 04:18 PM
S_NeWb's Avatar
i would say let the dyno shop tune. probably take them less than an hour lable verses wideband $ and taking chance with friend
Old Feb 22, 2007 | 05:12 PM
ATOice's Avatar
Don't need it, but it would be advised.
Old Feb 22, 2007 | 05:38 PM
gomarlins3's Avatar
...or you could get a wide band and do it on the dyno since your wide band would be more accurate than the dyno's sniffer.
00S2K01S4
Oct 30, 2008 12:26 PM
00S2K01S4
26
Aug 19, 2006 03:31 PM
LudeAtic
Jun 3, 2005 07:32 AM
modifry
Apr 21, 2004 05:29 PM
wortham
Nov 2, 2003 06:27 PM
