Setup change to EFR
Old Mar 6, 2015 | 09:07 AM
nissfam's Avatar
Default Setup change to EFR
After some issues with my current setup I have decided to switch to a full race/EFR setup. I have a sleeved 9:1cr, 2.4L motor with ported head that currently makes 550whp on pump fuel. My power goals are the same as now for pump fuel... I will do a race gas calibration as well and will be looking at the 700-750whp range on that fuel.
The Borg EFR 9180 is my choice and was wondering how that turbo responds... Any input is wonderful
Old Mar 6, 2015 | 09:28 AM
Jin_SK's Avatar
BorgWarner has a matchbot application that will show you roughly how the car will work on the map. Based on a estimate it looks like it might be a little laggy up to about 5k. You will probably want the externally gated 1.45 A/R 9180.
matchbox
Old Mar 6, 2015 | 09:32 AM
nissfam's Avatar
Thats one of the things I was wondering about... The 1.05 or the 1.45. Does anyone here have this setup?
Old Mar 6, 2015 | 11:15 AM
Jin_SK's Avatar
There aren't a ton of people on the EFR, let alone the 9180. I have the IWG 7670 and I think someone did the 8374, not sure. There's a bunch of EVO/STI guys that have the 9180 and are making the power you're looking for and I'd be shocked if the S2000 couldn't do similarly.
Old Mar 6, 2015 | 11:31 AM
Alloy Craft's Avatar
Former Sponsor
What turbo are you running now?
Old Mar 6, 2015 | 02:37 PM
AE85's Avatar
From what the guy said, the 8374 didnt fit. It was just physically too big. Im sure you can get around it with a cut off wheel
Old Mar 6, 2015 | 02:38 PM
AE85's Avatar
What are the numbers with your 7670? Any issues holding boost?
Old Mar 6, 2015 | 03:09 PM
Jin_SK's Avatar
Originally Posted by AE85
Originally Posted by Jin_SK' timestamp='1425672917' post='23530141
[quote name='nissfam' timestamp='1425666764' post='23529993']
[/quote]
495whp/402tq on E85 and 397whp/293tq on 91. Boost holds pretty pretty well other than the seemingly typical spike at ~4500.
Old Mar 6, 2015 | 04:27 PM
ZSAK's Avatar
I wonder what 7064 will do
Old Mar 6, 2015 | 06:04 PM
Jin_SK's Avatar
I'd only run that turbo that small on a stroked motor with a lower rev limit (~7000), otherwise you'd be way overspinning it. Even then the 7163 is would be a better choice.
