Damn that's sucks dude, if I was you I would start a new thread that you need help or edit your tittle on this one. Sorry I can't b of any help.
datalog?
boost cut??
How much boost to make the 460whp? What fuel? Did you figure out what was causing the fuel cut?
Be careful not everyone can hear it but popping can be knock, or as above your hitting fuel cut but it'll be aggressive and you'll see from the exhaust haha. If you play with boost control it becomes quite sensitive in various scenarios (not warm up a hill etc etc) and is more likely to hit fuel cut due to overboost.
The only thing I'd say is fit a brace for the turbo it'll probably crack the manifold in time with that big arse turbo on it and those vents do as you guys say 'jack shit' unless your stationary, get a vented bonnet with louvres to pull out the hot air on the move and when stationary. |
Originally Posted by s2konroids
(Post 23668747)
The only thing I'd say is fit a brace for the turbo it'll probably crack the manifold in time with that big arse turbo on it and those vents do as you guys say 'jack shit' unless your stationary, get a vented bonnet with louvres to pull out the hot air on the move and when stationary. It's running fine now after disconnecting the vacuum line from the PCV. Maybe oil in the line was preventing the wastegate from opening?I think it may have been knock and the EMS was cutting fuel? You really think I need to worry about manifold cracking? I find it very hard to believe that those vents don't let heat out while moving. Also, here is the dyno: https://scontent-lga1-1.xx.fbcdn.net...1e&oe=561D8D6B WOT 2nd Gear last night [media]http://www.youtube.com/watch?v=zyoex9Weh-c[/media] |
sounds sweet man. now go eat up some V8's!!! :wine:
Originally Posted by JuicedS2K
(Post 23668912)
The only thing I'd say is fit a brace for the turbo it'll probably crack the manifold in time with that big arse turbo on it and those vents do as you guys say 'jack shit' unless your stationary, get a vented bonnet with louvres to pull out the hot air on the move and when stationary. It's running fine now after disconnecting the vacuum line from the PCV. Maybe oil in the line was preventing the wastegate from opening?I think it may have been knock and the EMS was cutting fuel? You really think I need to worry about manifold cracking? I find it very hard to believe that those vents don't let heat out while moving. Also, here is the dyno: https://scontent-lga1-1.xx.fbcdn.net...1e&oe=561D8D6B WOT 2nd Gear last night [media]http://www.youtube.com/watch?v=zyoex9Weh-c[/media] No because they can't let the heat out on the move, when completely still they will on the move nothing, lourves pull the heat out. Upto you. |
Just my 2cents, the only Sheepey s2000 manifold I have ever heard of cracking was Ulmighty's and his cracked on the wastegate flange, no where else. Sheepey fixed the manifold for him. On an additional note, these Sheepey Built manifolds carry a 10yr warranty. But I do agree it is a decent amount of weight hanging off of it and the extra support definitely won't hurt.
Yup my wg flange came off my manifold. As I remember sheepey admitted at fault. It looks like a samurai sword went and cut it clean. Anyways he fixed it no issue just make sure the dumptube wasn't hitting the hood since is hood exit.
