should i drive 3 hours on base map to get to tuners?
I'm looking at bringing my car to topspeed and they want to charge me 1k for install and then 300 for wiring my uego and tru boost into my ems but I can do that all myself. The issue is the closest tuner is topspeed which is 3.5 hours away and I don't know if I should drive on a base map that far. What are you guys' opinions. What should I do?
Running on the base map is fine as long as you stay out of boost. You can always install everything but leave the charge pipe off the throttle body and rig up some kind of intake with a filter. Use the injector flow rate wizard in the AEM so you can install the injectors.
Tow it.
Is this just an EMS?
Even if it's installing the EMS, wiring the UEGO, and wiring the Truboost, $300 is too much. Butttt...it will probably take 2 hours to do, but it's easy. It's just me (well not just me) but working on your car is too much fun to pay someone else to do it. The only thing I'd pay for is a diff installation or a clutch.
Or is the $1K to install a whole FI kit?
