Silicone intake heat exchanger type 101 install
Old Oct 20, 2014 | 02:13 PM
donaldmejr's Avatar
Default Silicone intake heat exchanger type 101 install
So guys I bought a type 101 heat exchanger over a year and half ago and never got around to installing it. Well with my new job giving me days off now I finally did.
Here is the link to the heat exchanger I bought.
http://www.siliconei...ger-p-1026.html
And the pictures of the brackets I made.
And how it sits with the bumper put on.
Old Oct 20, 2014 | 02:46 PM
Chance S2K's Avatar
Wow, that looks really clean and high quality!
Old Oct 20, 2014 | 04:31 PM
iDomN8U's Avatar
I had the top and bottom mounts rewelded to the sides of the hx and self tape screwed to the car front support. I didn't get it from them but it looks like the exact some HX.
Mines not dead straight due to using straight connectors but it's close enough not to bug me
Old Oct 20, 2014 | 04:41 PM
donaldmejr's Avatar
I rather not use self tappers. I made the brackets to fit in the same spot as SOS uses and wanted to be able to just in case I needed to go back to SOS's heat exchanger. I still need to clean up a few of the brackets, round the edges, and paint the whole unit black.
Old Oct 21, 2014 | 04:55 AM
iDomN8U's Avatar
Looks great, I agree it's a much better setup then mine. Due to the width it's able to be tapped into the supports, just making that info known.
Old Oct 21, 2014 | 05:37 AM
CoolGuy094's Avatar
Ah nice, you bought the big-boy one! Hahah. Good to see someone mounting that giant thing in there; I think one other person on here had used the thicker one in the past.
Old Oct 21, 2014 | 08:59 PM
cheddaboy's Avatar
DAMN!
Old Oct 22, 2014 | 04:38 PM
camuman's Avatar
Well that def will help with removing heat. When is the car going to be up and running?
Old Oct 22, 2014 | 05:09 PM
RAIN H8R's Avatar
My god thats huge. I opted for the frozen boost 2inch core and i that was overkill!
Old Oct 22, 2014 | 05:15 PM
donaldmejr's Avatar
I'm not sure taking it slow and changing a few little things.
Maybe a ZDX 80mm throttle body and I'm going to send it and the intake manifold to max bore. Other then that SOS fuel pump rewire kit. Not sure after that maybe change the pulley sizes both crank and blower for better anti slip.
Sent from my iPhone using Tapatalk
SUS2K
24
Feb 7, 2008 12:02 AM
itS2Krazy
38
May 28, 2006 02:18 AM
phillys2k
May 11, 2005 08:53 AM
jays2000
Mar 9, 2003 06:39 PM
