Simulated Narrowband O2 Output
Hi All
I have purchased a Zeitronix data logger mainy for A/F logging, the primary O2 needs to be replaced with a wideband, the device has a 02 output to feed the ECU from connector C16.
After some research, i found out that a resistor is needed on other similar devices.
If I need such resistor, which connector/s should i connect it to ?
Thanks
Thanks
Hi Trip, im pretty sure you will because you are unplugging your old sensor completely and the ECU will expect to see a circuit from the Heater + and - wires. When you disconnect the plug you will get a CEL.
I am doing mine tomorrow (PLX) and am going to connect the resistor onto the open ended plug. Its the 2 white wires you want. Not sure how I will secure it in place yet.
You can also do it at the ECU and one of the other connector plugs. I didnt want to do it there as the resistor gets hot.
Theres another thread on this recently in this forum, will try find it.
MB
MB
Is this the post
https://www.s2ki.com/forums/index.php?showtopic=327311
I understood i need to short C1 with 101/104 using the resistor
where is 101/104 located on the ecu harness ?
Its not on the ECU harness, its on a connector plug that sits next to the ECU. You can see a picture of it in the link below.
http://alavigne.net/newHomePage/Motorsport.../M500/index.jsp
MB
MB
Sorry for bring this back from the dead, but I need to know which pin in C101/404 it needs to be. Is any BLK/YEL wire okay to tap for +ve?
My thread:
https://www.s2ki.com/forums/index.ph...&f=26&t=806886
My thread:
