Single disk option for V160?
The flywheel is completely custom. You would have to check with Full Blown to get the entire details for the single disk. I think most of the V160 users chose the twin disk.
There was also mention of it using all the stock v160 components such as the clutch plate, pressure plate, shift fork, slave cylinder, etc.
The initial cost of a twin disk setup is very expensive, but it is also rebuildable for a small fraction of the initial cost. A twin disk will provide more clamping force without having a really stiff clutch pedal feel like a high sprung single disk, but if it is OEM it should feel like stock. I'm not too sure of what the OEM Supra clutch is rated at torquewise either.
S2KPUDDYDAD
Feb 5, 2007 05:44 AM
