sleeved block
Old Sep 23, 2008 | 04:48 AM
kutsujula's Avatar
whats the $$$
Old Sep 23, 2008 | 05:52 AM
JO TECH's Avatar
Originally Posted by fadiss2k,Sep 23 2008, 12:26 AM
correction...it has AEBS sleeves put in by inline pro. Supposedly just got out of the machine shop. Guys name is Tom and he lives in FL.
Old Sep 23, 2008 | 06:45 AM
fadiss2k's Avatar
Good eye JO!!!
So being a closed deck like that should i have an problems with heat?
Old Sep 23, 2008 | 07:24 AM
ERL_S2000's Avatar
The holes for you have already been drilled, so you do not have a full closed deck. You really only see that in drag racing applications.
Old Sep 23, 2008 | 02:03 PM
JO TECH's Avatar
Originally Posted by fadiss2k,Sep 23 2008, 08:45 AM
Good eye JO!!!
Thanks, I deal with these engines a lot. I have picked up a pretty good eye for spotting sleeves.
Be careful with ovebore f20 blocks, ive had a problem with the headgasket twice with overbored sleeves on turbo applications.
Old Sep 23, 2008 | 02:46 PM
ERL_S2000's Avatar
What were you seeing happen exactly? Was there a sealing problems between each?
Old Sep 24, 2008 | 12:14 AM
fadiss2k's Avatar
I did not want to hear that. Is there a fix for it so it seals right?
Old Sep 24, 2008 | 06:04 AM
snakeeater's Avatar
You could have O-rings installed. If done properly, that will seal just about anything. Call Inline Pro to discuss.
Old Sep 24, 2008 | 07:22 AM
2big4aS2000's Avatar
o rings a big PIA - done correctly you should cut the block and the head - now you will have to use a copper head gasket -
Old Sep 24, 2008 | 08:01 AM
GDM S2K's Avatar
ide rather my HG blow than my block blow thats why I didnt O ring
