Slick selection for AP1 rear tires
Okay so I am about to order these M/T ET street radials in 255/50-16. Is this adequate for my HP? I want to take the car to the track in a couple weeks and see if I can net myself low 11's high 10's with these tires. I'll be running my daily radials in the front and only switching out the rear tires once I arrive at the track
http://www.summitracing.com/parts/MTT-3793R/
Real street, thanks for the explanation on bias vs radial. That was helpful to learn that.
I have a question, I want to run high grip tires on the rear with AP1 wheels as well, but I'm in a supercharged application with around 425 whp (have not been dyno'ed yet) What size tire should I buy? Ill be running radial tires on front. But would a 26 in tall tire be to big? How do I know how wide I should get?
Okay so I am about to order these M/T ET street radials in 255/50-16. Is this adequate for my HP? I want to take the car to the track in a couple weeks and see if I can net myself low 11's high 10's with these tires. I'll be running my daily radials in the front and only switching out the rear tires once I arrive at the trackhttp://www.summitracing.com/parts/MTT-3793R/
after doing much research with my ap1 rears around numerous sfl shops, i went down the same boat-
Mickey Thompson 255/50/16 tires on ap1s- for the same reason. If fernando is running 9's on street
radials for gods sake, i dont see how you'll have a problem with your setup in the 600's o'malley.
I think you made a good choice with those- especially if you're running with 18's on front due to the
very close comparisons in wheel diameter. I havent went to the track yet to test mine out, so i
would sure love to see your experiences with them on film! good luck!
Hi , i got a oem 2001 ap1 with AEM coldair on 16 inch oem re760s , i ran 14.0@98mph , i need to make in 13 sec on 1/4 mille so i wanna know wich tire i should run to make 13 sec. I should run 16 inch radial like MT or bring good street tire like R888 or advan a048 ? Thanks
