Slow in cold weather?
Old Oct 21, 2008 | 08:01 AM
Sub2K's Avatar
Default Slow in cold weather?
ok so i just got my emanage ultimate not to long ago with a wideband, i hooked it all up adjusted the AFR target map and its been running really smooth but pretty much every night when its been really cold it runs crappy when i got WOT it feels like its holding back and the car doesn't want to go thru the band.
if its like around 80-70's outside it pulls way harder, could it have to do with my new plugs i have been running ?? i recently switched to BKR7Es NGK's.
Oh and i am running CTSC on 7psi
Old Oct 21, 2008 | 09:01 AM
Sub2K's Avatar
any ideas anyone ?
Old Oct 21, 2008 | 09:11 AM
TRBOKEV's Avatar
Who did your tune?
Old Oct 21, 2008 | 09:46 AM
SgtB's Avatar
The AFR target map is NOT autotune. I honestly wouldn't even use it as it gets freaked out pretty easy. You need to tune for temperature changes. As far as crappy: define crappy. Is it going rich, bouncing around?
Old Oct 21, 2008 | 09:47 AM
05TurboS2k's Avatar
sounds like a pig-rich running engine and its bogging from too much fuel. Cold = dense which means even more dense.
Who did your tuning at what is your AFR?
-G
EDIT...... posted faster then i could lol
Old Oct 21, 2008 | 09:51 AM
btstone84's Avatar
yeah, thats very odd. cold air means faster...........usually
Old Oct 21, 2008 | 12:07 PM
dsddcd's Avatar
Cold air means lower intake temperatures which will increase the mass flow into the engine. Then add the extra fuel the car needs due t the decreased fuel atomization and together they add up to more than Greddy tuned for. I noticed that I needed to add more fuel with a cold motor and chilly ambient using the water and intake I/J maps.
You may want to check this out.
http://www.amazon.com/Engine-Management-Ad...24619526&sr=8-1
Old Oct 21, 2008 | 12:20 PM
Sub2K's Avatar
thanks i will
Old Oct 21, 2008 | 12:22 PM
Sub2K's Avatar
i will post my afr map when i get home and i just had my buddy do a simple tune for safety but i do need to get it done ata respectful shop when i get a chance i was thinking of church but when i called i got this really rude mofo and i kinda wasn't sure anymore after that
Old Oct 21, 2008 | 12:25 PM
Sub2K's Avatar
i haven't been able to data log yet since the battery on the laptop crapped out but when i go wot it feels slow the rpm take longer then normal to get to red line it pretty much feels like im going like 1/2 - 3/4 throttle
