Slow Spool on S/C
Old Nov 11, 2006 | 09:52 PM
prorcracer87's Avatar
Default Slow Spool on S/C
i bought the kit used, about 10k on it
went in for dyno tune today and found out that i had a bad fmu(brand new tho) so ill send it out for service
but i have a vafc so they were messing around with just the injectors, they maxed out at around 6k without FMU.
for some reason the s/c makes boost really slow, and at about 6-7k, it was only at 5psi
from what i heard s/c makes full boost at around 4k-ish.
maybe its my s/c itself? it does rattle when its cold, but it sounds fine once it warms up, i think its gearlash but maybe im wrong?
TIA,
Cliff
Old Nov 11, 2006 | 10:41 PM
elusiv's Avatar
I dont know about everyone else, but I dont make full boost until nearly 9k, which is the way it should be.
If you're running a stock kit and hitting 5psi at 6-7k rpm, then 5psi isnt your peak boost.
Old Nov 11, 2006 | 10:52 PM
TRBOKEV's Avatar
Supercharger boost is in direct relationship with RPM, with it hitting its maximum boost at maximum rpm.
Old Nov 12, 2006 | 08:40 AM
joes sled 2000's Avatar
TIA,
Cliff
You have a centrifigal supercharger not a roots type.Simply put you will not make peak boost until redline.What you describe is normal .They tend to be a little noisy,almost like a cement mixure.
Old Nov 12, 2006 | 09:59 AM
Dsgs2k3's Avatar
defiantly roots type you are talking about, which will have full boost around 3-4k, unlike Cent. SC it will gain full boost at the max rpm the engine can spin
Old Nov 12, 2006 | 11:53 AM
that makes me feel a lot better...now i just have to buy another fmu and i should be ok
anyone sellin a used fmu?
2003blacks2k
Jan 31, 2011 11:18 PM
Envied
Oct 28, 2009 05:59 PM
nightcrawler7188
Apr 6, 2008 05:47 PM
PeanutButter
Aug 5, 2007 08:13 AM
D-S2K
Jun 21, 2005 06:52 PM
