"smoke coming from my oil catchcan"
Old Mar 21, 2010 | 06:20 PM
aznoophi's Avatar
Default "smoke coming from my oil catchcan"
so i was driving today and and out of no where there was smoke coming from the hood so i popped it and checked, and saw that the smoke was coming out of my catch can filter! is that bad? cause i never seen that before!~
Old Mar 21, 2010 | 06:31 PM
TRBOKEV's Avatar
Are you FI? What are you running?
Old Mar 21, 2010 | 06:47 PM
aznoophi's Avatar
yes im running a Garrett 35r with custom manifold!
Old Mar 21, 2010 | 09:15 PM
aznoophi's Avatar
any help?
Old Mar 21, 2010 | 10:19 PM
RedLineS2k10's Avatar
sounds like ur having the EXACT same problem i just had..I was on the dyno and all of a sudden when we turned the car back on the catch can was gushing smoke. Either piston rings or head gasket. I have a gt28rs and i was getting tons of oil vapor through the crank case vent tube, and then when i took the catch can off it smelled like gas/oil..Have u checked ur compression yet?
Old Mar 21, 2010 | 10:31 PM
soulicious's Avatar
How is your vented catch can plumbed?
Old Mar 22, 2010 | 03:09 AM
phils2k's Avatar
had something similar last weekend, on the dyno it started to breath heavy
opened it up a couple of days ago and found this oooops
bore wash. hopefully not as serious for you
Old Mar 22, 2010 | 05:13 AM
siadam's Avatar
Under load thats ok, if just ideling and you are seeing smoke, usually an indication of ringlands/rings gone bad.
Do a compression test and report back.
Old Mar 22, 2010 | 06:40 AM
Irishflame27's Avatar
ditto
Old Mar 22, 2010 | 06:59 AM
ap1tuner's Avatar
Yep my buddy's got the same thing going on with his 91 talon. And his exhaust is blowing smoke. But his compression was real good. We started guessing that the valve seals are shot!
