Smoke on initial start-up
Old Jul 25, 2008 | 06:20 AM
blueap2's Avatar
Default Smoke on initial start-up
On my previous turbo install on an RSX, I remember getting smoke on initial start-up. I just finished my turbo build last night with a full-race setup and was wondering how long your car smoked around the exhaust manifold area?
Thanks!!!
Old Jul 25, 2008 | 06:50 AM
passmans2kny's Avatar
prob until any residue of oil or whatever was on the manifold burns off, i dont think anyones gonna list a time frame
Old Jul 25, 2008 | 06:54 AM
kutsujula's Avatar
yep make sure you got 0 oil leaks cause if u got any oil leaks dripping in that area itll smoke
Old Jul 25, 2008 | 06:55 AM
blueap2's Avatar
well, it smoked a lot when it began warming up...after a couple more minutes, it decrease but when i reved the engine it would increase a slight bit...i just hope its not an exhaust leak..
btw, i tripled checked everything so i was just trying to get a general idea
Old Jul 25, 2008 | 06:59 AM
kutsujula's Avatar
You got a oil restrictor on the turbo?
Old Jul 25, 2008 | 07:09 AM
blueap2's Avatar
yup, well im pretty sure since im using the fitting you ^^^^ left there
Old Jul 25, 2008 | 07:13 AM
blueap2's Avatar
oh yeah 100% sure no oil leaks...only had one from the oil filter relocation kit and i fixed that
Old Jul 25, 2008 | 07:17 AM
kutsujula's Avatar
Double check the fitting to make sure thats the oil restrictor fitting and not just the fitting that comes with the turbo, if its a restrictor itll have like a pin point hole on the end accept the oil feed.
Old Jul 25, 2008 | 07:45 AM
blueap2's Avatar
I'll check that fitting out..this will cause the turbo to get too much oil right, which may result in smoking?
Old Jul 25, 2008 | 07:51 AM
05TurboS2k's Avatar
lol I just got my manifold back on day before yesterday, I've done it 4 times now.
Smoke lasts between 5 minutes and 30 minutes for me, really depends on how much oil and how hot i get it.
One time I must have bumped the oil line on top because it was making a wet area around the fitting so the smoking lasted all day I knew I hadn't split that much oil, I had to grind down a wrench to fit to be able to snug it up but it worked.
