SOME ADVICE PLEASE......
Old Jul 19, 2008 | 07:52 AM
FLYNLOW's Avatar
Default SOME ADVICE PLEASE......
HEY GUYS I JUST INSTALLED BACK MY FULLY BUILT MOTOR.(9;1 CR CP'S, INLINE PRO ROD AND DUAL SPRING- TIT RETAIN SET, SLEEVED AND BALANCED PLUPRINT DA WHOLE SHABANG..LOL) TRYING TO PUT A COUPLE MILES ON IT BEFORE I TUNE BUT INTERMITTENTLY THE SPEEDO GOE TO 0 THEN 15 AND SO ON WHILE IM DOING 60MPH OR SO AT THE SAME TIME THE TEMP GOES TO FULL HOT THEN 1 BAR BUT THE CARS NOT OVER HEATING AND THE WEIRDEST THING THE AC STOP BLOWING COLD WHEN THIS HAPPENS???? IM LOST NO CRIMPED WIRES CHECKED GROUNDS I JUS DONT KNOW... OOHH CURRENTLY IM RUNNING ULTIMATE KIT W/ EMA BLUE.
Old Jul 19, 2008 | 09:14 AM
Spec_Ops2087's Avatar
STOP SCREAMING
Old Jul 19, 2008 | 09:55 AM
fatjoe10's Avatar
Hmm, something similar happened to me when I forgot to reconnect the alternator after an engine install. Also, easy to forget is the ground that goes behind the cylinder head up against the firewall.. good luck.
Old Jul 19, 2008 | 11:44 AM
SgtB's Avatar
Are you absolutly sure the harness to the blue is correct, as well as the settings?
beaudin223
Nov 4, 2016 01:18 PM
NSXLITE
Oct 30, 2014 12:23 PM
CenturionS2K
Aug 9, 2011 01:48 PM
spaap1sup
Oct 7, 2010 02:57 AM
