SOS install need help on the vacuum lines.
Old Jun 17, 2012 | 04:27 PM
Ludeboye1's Avatar
Default SOS install need help on the vacuum lines.
I am having difficulty understanding their instructions on are not very clear and and there are no pictures for this step.
Sos's instructions
Airbox controller they are talking about
2 hoses they are talking about upper and lower
What they have provided 2 peices of hose and a "t" fitting.
There are 2 free hoses are the air control box once going out to the left of the big unit and one on the smaller controller I bolted on to the bigger unit. Which line goes where? They are talking about using factory hose for the upper line I am not sure which hose this is.. Can someone please clear this up for me I am stuck right now and dont really want to take the next step until I have this figured out
Also everyone said the guide from sos tells you which bad number to go to and I don't see this anywhere? All their bags are numbered but there is no reference in the guide that points you to a certain bag... Not a big deal but just thought it would be there.
Old Jun 17, 2012 | 04:29 PM
Ludeboye1's Avatar
The hose I am holding in my hand is coming from he left side of the control box unit.
Old Jun 17, 2012 | 04:46 PM
teamvalorracing's Avatar
20" long hose goes from the bottom hard line on the manifold to the port on the sensor where you have a small disconnected vac line in the pic.
then, use the line in your hand to go to the top port hard line on the manifold.
i believe the T is for connecting the BPV to a vac source and is not used in this step as well as the additional vac line.
Old Jun 17, 2012 | 07:32 PM
Ludeboye1's Avatar
Hey thanks I managed to get the fuel pump, crank pulley and the brackets done today. I also see how you guys make reference to the parts list and the install manual. It would be better if they just mark the bag number right on the manual itself with the pictures though.
pikkashoe
Nov 30, 2005 07:58 AM
ChrisWells
Jun 23, 2005 02:44 AM
hyperpm
Jan 21, 2003 02:33 AM
trbomx5
Jan 8, 2003 07:12 PM
